How to make Auger or Screw Conveyor ?  Topic is solved
The ideal place for beginners to get help using SketchUp
Postby hulahopka » Mon Nov 05, 2012 7:18 pm
I modeling some transport Screw Conveyor or auger, and I can get idea how modeling spiral part. I can use one of final solution from 3d warehouse, but I like to learn how for next time. I try all kind of plugins, like spiral stairs, helix, screw, screw 21, but I cant figure how that plugins work, maybe is problem because my native language is far far away from english :) Slovenian and I cant get the point of subject, if I expressed correctly.
I look and try with this exsample and no way to get result, I try with all kind diferent point selected and no sucess.
hulahopka
Re: Ho to make Auger or Screw Conveyor ?
Postby Gaieus » Mon Nov 05, 2012 7:26 pm
Hi Hulahopka,
Someone with words like zmrzlina (and can even pronounce it) should not fear from any other languages in the World (maybe just Portuguese).
So how far did you get with your spiral?
Postby watkins » Mon Nov 05, 2012 7:35 pm
Perhaps this will help
http://www.youtube.com/watch?v=pNTetL3Udkc
Regards,
Bob
watkins
Postby hulahopka » Mon Nov 05, 2012 9:06 pm
Hi. @Gaieus Ha ha I get the point :) Zmrzlina is not Slovenian I thik is Czech word for Ice Cream, Slovenian word is even more funny, Sladoled :)
@watkins I will try this tutorial, maybe I succeed
So my problem is, if use helix plugin, make curve and then draw a taper, model become non simetric, I use rectangle and folow me tool, but this rectangle not folow curve nice and start spin around curve, if I say rihgt.
thank you.
hulahopka
Postby ely862me » Mon Nov 05, 2012 10:39 pm
I think you need this plugin Follow me and keep viewtopic.php?f=323&t=16465 .
Cheers !
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
Postby pbacot » Mon Nov 05, 2012 10:52 pm
FMAK is pretty much a "required" plugin--for most users--eventually.
If you are a using a plugin on this one though. I say screw.rb. If you can find a section profile for the auger, it does the rest.
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby Gaieus » Mon Nov 05, 2012 11:22 pm
Damn, I would have sworn that the word is also used in Slovenia, sorry.
Back to the shape: indeed that plugin is what you need. It could also be made manually but that's of course more tedious.
Re: How to make Auger or Screw Conveyor ?
Postby pbacot » Tue Nov 06, 2012 3:30 am
Gai,
What happened to my draft. I saved and it's gone :cry:
Here again. First I wish to put up a video on using the screw.rb. If you have more questions you can come back here.
Rich gives a blow by blow here: viewtopic.php?f=15&t=15784&start=15#p245701
Screw.rb might be difficult at first but experiment. With the follow mes you'll never get this:
or this:
Top SketchUcator
Postby hulahopka » Tue Nov 06, 2012 4:02 pm
@ely862me That's exactly what I needed, could not be better.
I make this Screw Conveyor and for me is look OK, I got just few problems.
If I make a tube, and I want to put helix in that tube, I cant. This would save me the time with settlement of the pipe axis, and scale Conveyor to adjust inside teh pipe.
But I'm still happy :ecstatic:
Thank you all for support.
"off topic"
@Gaieus I apologies, it has word zmrzlina in slovenian :) But allmost no one use this word anymore, I found word only in few old recipes for candy. So you were right, again :)
hulahopka
Postby pbacot » Tue Nov 06, 2012 4:19 pm
Looks nice! The trick with the tube may be learning alignment techniques and using the same number of sides for the tube as for the helix.
Hey look! Gaieus is happier today!
Top SketchUcator
Postby hulahopka » Tue Nov 06, 2012 4:35 pm
Hi. Is there some good tutorial for alignment techniques ? I will use google and youtube, but if anyone know some good one, it wont be bad :)
Thank's
hulahopka
Re: How to make Auger or Screw Conveyor ?  Topic is solved
Postby pbacot » Tue Nov 06, 2012 4:47 pm
hulahopka,
For alignment: See Dave's Post here where he gives a link to his tutorial where it says "this" http://sketchucation.com/forums/viewtopic.php?f=79&t=48824&p=438636#p438550 (and you might look at the whole rest of the thread too).
Top SketchUcator
Postby hulahopka » Wed Nov 07, 2012 2:19 pm
Hi, I got problem again, how to cut hole from one pipe to another, for T connector like I do on sample ?
hulahopka
Postby Gaieus » Wed Nov 07, 2012 2:39 pm
The exact method depends on whether they are groups/components but basically you do it by intersecting. Select all the geometry > Right click > Intersect selected (or model) then delete the geometry in the "holes".
If the pipe is in a group/component, edit it first (double click) and do the intersection (now only with model works) inside.
Postby hulahopka » Wed Nov 07, 2012 3:45 pm
Hi. I success :)
Cyan pipe is group, I not create T part of pipe in that group (avoid some errors with slection etc) So I make this part separate on this group, make guide first, on that guide make circle, use push/pull tool to make cylinder, then with offset tool make another circle on top of cylinder, push/pull tool and make tube, triple click on what I make, go to Edit / and copy this object. Delete object, open grouped cyan tube and goto Edit / paste in place, right click on pasted part and select Intersect faces / with model, then delete parts that do not need.
Maybe this will help some newbie like me :)
Thank you again.
hulahopka
Return to Newbie Forum
Users browsing this forum: Bing [Bot] and 6 guests
