Dimensioning
The ideal place for beginners to get help using SketchUp
Dimensioning
Postby mk11 » Sat Dec 29, 2007 4:05 pm
Problem: After extruding walls in a building i want to dimension interior and exterior walls and openings, but but my dimensions appear "on top" of the extruded walls instead of on the floor plane. How can i insert dimensions on the floor plane after walls have been extruded?
Thanks,
mk
Marc Kleinmann
SU Pro 2015
Mac & Win
mk11
Premium Member
Premium Member
Re: Dimensioning
Postby Jim » Sat Dec 29, 2007 4:07 pm
Dimensioning is a little weak in SketchUp. You can move Dimensions using the Move Tool. The other option is to delete and add new ones.
There are a few Dimension settings in the Window > Model Info > Dimensions menu.
Jim
Global Moderator
Re: Dimensioning
Postby mk11 » Sat Dec 29, 2007 4:08 pm
But how can i add the new ones so they will appear on the floor plane?
Marc Kleinmann
SU Pro 2015
Mac & Win
mk11
Premium Member
Premium Member
Re: Dimensioning
Postby rhankc » Sat Dec 29, 2007 5:54 pm
mk11,
I found my quickest work thru was to place a line from the exterior centerpoint of the opening that was above the floor plane down (blue) to the floor, this was my pick point for dimensioning. Mostly I deleted them at the next ISO view, but if you place them in their own layer, you can use them again.
I like the dimensioning capabilities of SU. It is extremely flexible,stable and easy to modify, and with a little technique modification on my part it is quite easy to dimension a plan to my tolerances.
Regards,
Hank
rhankc
Return to Newbie Forum
Users browsing this forum: Bing [Bot] and 3 guests
