cast shadow from transparant face?
The ideal place for beginners to get help using SketchUp
Postby bravilor » Thu Dec 20, 2007 4:53 pm
Can someone please explain some things about casting shadows from transparant faces?
Sketchup-help function says transparent surfaces only cast shadows above 70% opacity but how can you explain this:
Both 'bryce' and the cube are painted with the same material at 25% opacity, both are components with 'cast shadows' turned on and yet the cube does not cast shadows...
What am i missing here? Thanks in advance :)
bravilor
Re: cast shadow from transparant face?
Postby Gaieus » Thu Dec 20, 2007 4:56 pm
Well, the case is that neither should cast shadows... Bryce is the curious thing here... :shock:
Are both sides of Bryce painted? with this transparent material?
Postby bravilor » Thu Dec 20, 2007 5:02 pm
yes, both sides are painted...
here's the skp to check:
Untitled.skp
weird :?:
bravilor
Postby Gaieus » Thu Dec 20, 2007 5:09 pm
Still it's got something to do with the "face me" property - if you uncheck that, Bryce won't cast shadows either and vice versa - if you check that for the cube, it will also cats shadows.
Still weird why a face me component should behave differently.
Return to Newbie Forum
Users browsing this forum: No registered users and 5 guests
