Stamp tool alteration
The ideal place for beginners to get help using SketchUp
Postby rhankc » Sun Dec 02, 2007 5:39 am
Top-o-the-day-to you.
If you use the stamp tool to imprint an impression into a topographic plan. and at some period later in the process want to change the offset or depth or position of the stamp in the topo, can this be done? or is the web of lines too complicated to accomplish in a efficient method?
Or, is it better to start over?
Thanks, Hank
Hank
rhankc
Re: Stamp tool alteration
Postby Gaieus » Sun Dec 02, 2007 5:40 am
Hank, the offset cannot be changed later. The elevation (depth) can, especially with simpler stamps: just select all thet's stamped and move it up/down. To a certain extent (within the boundaries of the offset) you can even carefully move it side ways this way.
Postby ehaflett » Sun Dec 02, 2007 5:41 am
rhankc, just yesterday I dug up this nugget regarding the stamp tool and found it pretty helpful (thanks Gai).
viewtopic.php?f=96&t=2599
ehaflett
Postby Gaieus » Sun Dec 02, 2007 5:42 am
Hm...
These cross references are the sweetest things to transfer to the other board... :)
Yeah, actually you guys here are the biggest intuitions - I don't really use the terrain tools so every time there's a question like this it's a kind of challenge...
Postby ehaflett » Sun Dec 02, 2007 5:43 am
Sorry Gai, I'm sure these cause nighmares for you guys moving the posts. :? I'll keep that in mind when posting until we're all moved over.
Reason: Never mind Eric - I managed to find it ;)
ehaflett
Postby rhankc » Sun Dec 02, 2007 5:45 am
Gai and ehaflett,
thanks for the thread.
The main part of the stamp to be modified would be outside of the offset. When a building has to be moved some distance like 3-6 ft. across the site. I havent been able to successfully accomplish this except by starting over. maybe grouping the stamp and then carefully moving it....
you can nix the reference to the thread, i read it. and thanks.
Hank
rhankc
Postby rhankc » Sun Dec 02, 2007 5:46 am
Well Gai, for not using the tool, I think you handled it well. i would have considered your line of work a natural usage of the terrain tools, with all excavations you see. Intuitions...is that any thing like a pita? ;)
Hank
rhankc
Postby Gaieus » Sun Dec 02, 2007 5:47 am
ehaflett wrote:Sorry Gai, I'm sure these cause nighmares for you guys moving the posts. :? I'll keep that in mind when posting until we're all moved over.
Never mind Eric - sooner or later we need to transfer everything and updating these references is just a snap ( :roll: )
Hank wrote:Well Gai, for not using the tool, I think you handled it well. i would have considered your line of work a natural usage of the terrain tools, with all excavations you see. Intuitions...is that any thing like a pita? :ewink:
Well, I'm just getting into a project where I'll need to use it, I guess.
Otherwise whatever we measure (survey) out in the field, I usually process through with Didier's cloud script.
And a little experience in a tool that one does not often use, has never harmed anyone!
Postby Edson » Sun Dec 02, 2007 5:47 am
rhankc wrote:I havent been able to successfully accomplish this except by starting over. maybe grouping the stamp and then carefully moving it....
i always keep a virgin version of the terrain in case i have to start over.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Gaieus » Sun Dec 02, 2007 5:48 am
Edson Mahfuz wrote:i always keep a virgin version of the terrain in case i have to start over.
Ah yes, that's why you needed help with restitching your terrain once I remember...
?D
Mayeb that was the "lesson" I believe...
Postby Edson » Sun Dec 02, 2007 5:48 am
exactly. that thread was pure gold. i learned a LOT from it.
Edson
Global Moderator
Postby Gaieus » Sun Dec 02, 2007 5:49 am
Too bad it's gone (by the wind...)
Postby Edson » Sun Dec 02, 2007 5:49 am
in case it is needed i have tom's skippy and a hard copy of the main discussions.
Edson
Global Moderator
Return to Newbie Forum
Users browsing this forum: Bidder and 5 guests
