Not a Newbie but Its a new problem I've never come across be
The ideal place for beginners to get help using SketchUp
Postby Tobobo » Sun Dec 02, 2007 2:08 am
I'm creating a seating component to use (and share) but there is some issue with deleting lines. When I delete one of the lines that aren't required, it becomes a profile thickness line and won’t delete unless I delete the face it is on and then it will delete.
There are three components in it as it is a wooden seat with cham corners but it happens on most if not most of the lines!
It’s getting frustrating and I would like to know if it happens on your machines as well.
Type 5.skp
Toby
Philippians 4:13
Tobobo
Re: Not a Newbie but Its a new problem I've never come across be
Postby Jackson » Sun Dec 02, 2007 2:11 am
OMG, that is weird! I have no idea why that is happening, there don't seem to be any locked groups or geometry- was any of it locked in the past? I think this file should be posted in the bug forum and emailed to Google for them to run a bug check.
The good news is that the workaround really simple- just copy and paste it into a blank file and then it behaves normally.
Type 205 Fixed.skp
Jackson
Jackson
Postby Edson » Sun Dec 02, 2007 2:11 am
have you tried working in wireframe and then deleting the lines?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Tobobo » Sun Dec 02, 2007 2:12 am
Thanks Jackson and I'll try the wire frame thing as well Edson.
Toby
Philippians 4:13
Tobobo
Postby Gaieus » Sun Dec 02, 2007 2:12 am
Guys,
I guess the problem is that there are these components and layers all around in the model piled up on top of each other. I mean the same geometry appears on different layers but in the very same place. You sometimes don't even know when editing what in the model thus deleting geometry from one component while thinking that working on another one.
Turning off all the layers with the components but eploding the rest (I think on layyers2 when I started) allowed me to clean up that part pretty easily while when the components came into picture, they caused the mess again.
Jackson, when copying into a new model, did you copy everything? I mean all layers turned on and things like that?
Postby Jackson » Sun Dec 02, 2007 2:13 am
Ah, that explains it. I only copied whichever layer was active, but I guess there was geometry within that group on another layer.
Jackson
Jackson
Postby Gaieus » Sun Dec 02, 2007 2:14 am
Just look at the file size difference! :) You probably just copied a fraction of what was there!
Postby nomicrowave » Sun Dec 02, 2007 2:14 am
Tobobo,
I'm very much a newbie myself so I don't know if this will help you or not but I played with your file.
I deleted everything on levels 0 and 1, then redrew the front portion of the seat.
I don't know how to paste a link to a file, so here's a jpeg. The file is in the Newbie folder on the sketchucation page.
Is this what you're looking for?
Nomi
nomicrowave
Postby Tobobo » Sun Dec 02, 2007 2:20 am
Here is the finished article
http://www.sketchucation.com/scf/viewto ... 105&t=3715
Thanks for all your help guys
Toby
Philippians 4:13
Tobobo
Return to Newbie Forum
Users browsing this forum: LloydBri1, riko123 and 8 guests
