school project
The ideal place for beginners to get help using SketchUp
school project
Postby not registered yet » Sat Dec 01, 2007 5:34 pm
hey :)
im using skecthup in this school project and since im a new user some help once in a while would be nice :)
so far ive been able to figure most of it out by myself but ive run into a problem with surfaces i seem to be unable to make 4 surfaces i need :( i can send the file if you want it so that you can see it for yourself as it makes it easier...
Woller
Edit: i change the question if i got a new question so i wont spam the forum
not registered yet
Re: school project
Postby FormalyKnownAsMartin » Sat Dec 01, 2007 5:35 pm
Hi woller,
this is what I found at the SU-Help:
http://sketchup.google.com/support/bin/ ... pic=&type=
Tape Measure tool
With the Tape Measure tool, you can draw both Guides (a continuous dashed line with no endpoints) and Guide points(the endpoint of a fixed-length dashed line).
To draw a Guide, click on any point on an edge between its two endpoints, draw away from the edge, and then click to set the position of the guide, which is a dashed line parallel to the edge. As you are drawing, you can also determine the position of the guide by typing an exact distance in the "Value Control Box" ("VCB").
To draw a Guide point, click an endpoint, for example, the end of a line or the corner of a rectangle, draw out to the point where you want the Guide point to be placed, and then click to set that endpoint.
Have fun!
Martin Habes
Premium Member
Premium Member
Re: school project
Postby Gaieus » Sat Dec 01, 2007 5:35 pm
Woller,
well, Martin was quicker (cross posting :)) but still I send the post...
If you start drawing your guide line from an endpoint (midpoint) or an intersection point (green or black inference indication)), it will be a a guideline with a guidepoint at the end.
If you start from somewhere on a line or a midpoint however (red or cyan inference), you can draw infinite guidelines.
See also the SU Guide:
http://download.sketchup.com/OnlineDoc/ ... easure.htm
Re: school project
Postby Chris Fullmer » Sat Dec 01, 2007 5:36 pm
Woller, I think you edited your original post with a new question so as to not "spam the forum". I'm afraid no one will notice this technique here though and your nexw question will go unanswered. You might as well just start a new thread so everyone can see it.
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: school project
Postby Gaieus » Sat Dec 01, 2007 5:36 pm
:D
Hey Woller, Chris is right!
Very bad tactics - for several reasons!
There is a fine server upload system here for files, look at this topic here:
http://www.sketchucation.com/scf/viewto ... f=66&t=964
There you can upload your model (or actually you can use the warehouse, too) or you can attatch it here if it's not too big (we encourage everybody though to use Kelly's server for this way we can keep running this forum better).
Return to Newbie Forum
Users browsing this forum: rodie and 2 guests
