Simplify poligons
The ideal place for beginners to get help using SketchUp
Simplify poligons
Postby not registered yet » Fri Nov 30, 2007 1:24 pm
I've a question about polygons in sketchup. From our architect I got a 3D model of our house. I imported it into sketchup V6. It looks pretty good. Now I like to reduce the amount of polygons because the file has over 17 MB and I like to place the model in google earth. Is there an automatic method to reduce the polygons, or shrink the file size?
Kuesel
not registered yet
Re: Simplify poligons
Postby Krisidious » Fri Nov 30, 2007 1:25 pm
mmm... not to my knowledge, there are scripts in other programs that can do that like 3D Max...
you can purge your model, under model info. but I think you're stuck manually simplifying the model.
I could be wrong... there easily could be some clean up scripts. check out http://www.smustard.com and didier's ruby site. http://www.crai.archi.fr/RubyLibraryDep ... _Depot.htm
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Gaieus » Fri Nov 30, 2007 1:25 pm
Kuesel,
It can also be so big because there are no components used for repeating geometry. If you can change some such geometry into components (and use those as multiple instances) it can considerable decrease your file size. Unfortunately this is again a long and manual process.
However 17 mb sounds pretty big. The limit in the 3D Warehouse (if you want to export it to GE via that) is 10 mb. Sure you can export the "pure" kmz file, too but consider the render time in GE, too. This would be an extremely slow model.
Postby modelhead » Fri Nov 30, 2007 1:25 pm
Depending on the type of file there are a lot of export options available to reduce the amount of data that is carried along with the exported file. If all else fails it would be good to ask your architect if he could export a few versions for you. Ask him about the options that are available to him. Quite often these settings are overlooked.
Cheers!
modelhead
Return to Newbie Forum
