Scaling from Cad
• Page 1 of 1
Scaling from CadDoes anyone know when we open a cad model in Sketchup that it is 10 times larger in scale than what is supposed to be? And what are the settings to fix?
Re: Scaling from CadI have had the opposite happen to me I exported to dwg but the format scale was 1000 times off, changing my units from meters to mm helped there
![]() Rob Moors
Architecture Student Re: Scaling from CadThe dfx files that I import always blow up. I have to resize them to .0833333333. (I think I have too many 3s'). The interesting thing is that 1 inch to the dfx is 1 foot to sketchup. At least it is consistent and so once I knew the relative scales it was easy to resize. I also found that it was an advantage to position the model to 0.0 in SU (if you know in advance where 0.0 and the position of the base point is in the native 3d app.) before it was exported back to the native cad engine it came from. In all cases the model came back dead-on in position with the other components of the application it was being rendered with. In this case the application is a set of design tools used by home builders contractors and architects. It is a 3d tool but it is mainly component based to make it easier and quicker to build and then creat a bill-of material. The models that I build must have the proper math with them and must be positioned correctly or the application fails of course. Anyway, even if it starts out the wrong scale, the good news is that SU can fix it.
Re: Scaling from Cadofftopic: Bruce, I really like your new avatar, those candyapples ROCK!
Scaling can be a problem, fortunately I haven't had too many problems with this though. Save the Earth, it's the only planet with chocolate.
Re: Scaling from CadHey Juju...they are tasty looking arn't they. Just want to bite into one.
Cheers!!
• Page 1 of 1
