Can't select individual surfaces created with push too.
The ideal place for beginners to get help using SketchUp
Postby not registered yet » Fri Nov 30, 2007 4:45 am
I created a room volume by first laying out the floor plan in top view and then push up the layout to create the ceiling and walls. Now I can not select the floors, walls, etc individually to add unique fill to each. How can this be corrected?
P: jimf233
not registered yet
Re: Can't select individual surfaces created with push too.
Postby Edson » Fri Nov 30, 2007 4:45 am
could they be grouped? try clicking twice on the whole thing.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Masta Squidge » Fri Nov 30, 2007 4:46 am
Either they are grouped as he said or you smoothed the corners. Smoothing the corners would make the whole object be one solid face.
Masta Squidge
Postby not registered yet » Fri Nov 30, 2007 4:46 am
thanks, they were grouped. Now another issue I am having is how to scale components from the library. Can there dimensions be changed?
P: jimf233
not registered yet
Postby Masta Squidge » Fri Nov 30, 2007 4:47 am
just use the "scale" tool and it will show up with a bunch of litle boxes on a frame around it.
grab one of the corners and drag it to increase or decrease the size.
Masta Squidge
Postby Jean Lemire » Fri Nov 30, 2007 4:48 am
Hi folks.
Te resize components like doors and windows, for example, you may need to use the Move Tool to avoid changing the frame size while changing the door or window size.
Just ideas.
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Jean Lemire
Global Moderator
Return to Newbie Forum
Users browsing this forum: No registered users and 4 guests
