Angles in Degrees
The ideal place for beginners to get help using SketchUp
Angles in Degrees
Postby not registered yet » Fri Nov 30, 2007 4:29 am
To All:
I need to create a site plan from a survey. For accuracy, this will require entering the angle units in degrees, minutes and seconds. Is this possible in SketchUp? If so, how?
Thanks in advance,
Bill
P: BillLen
not registered yet
Re: Angles in Degrees
Postby Krisidious » Fri Nov 30, 2007 4:30 am
yes it is... let me help... one sec.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Fri Nov 30, 2007 4:31 am
Didier Bur has a few survey tools
http://www.crai.archi.fr/RubyLibraryDep ... c_page.htm
bottom of the page... Survey Tool.
this should be perfect for you...
also, in SketchUp you can import dwg files and other land survey format files, and all elevation data will be imported with it. meaning lines will come in at their real elevation
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby not registered yet » Fri Nov 30, 2007 4:32 am
Thank you Kristoff. Just what the doctor ordered!
P: BillLen
not registered yet
Postby Krisidious » Fri Nov 30, 2007 4:33 am
noooo problem.
let us know if you need anything at all.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby not registered yet » Fri Nov 30, 2007 4:33 am
Hi Kristoof,
Thanks for asking.
I have downloaded and installed surveytool.rb, but it will only turn an angle of ninety degrees regardless of what numbers I input. I tried tuning off angle snaps, downloading and reinstalling the script, but it continues to insist on drawing lines at ninety degrees only. Any ideas?
Also, it doesn't appear to draw curves.
Thanks again,
Bill
P: BillLen
not registered yet
Postby Krisidious » Fri Nov 30, 2007 4:34 am
you prolly need to go into your file preferences and change the angle tolerance from 5 degrees to .1 or .01
try that and come back if it doesn't work.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby not registered yet » Fri Nov 30, 2007 4:34 am
Kristoff,
I don't see anything in Preferences that relates to setting angles. Under Windows - Model Info - Units, there is a place to set Angle Units - Precision, which I have set for 0.000 and I turned off Angle Snapping there as well. Still the problem persist. Sounds like there may be a bug in this script. Is this script working for you?
Bill
P: BillLen
not registered yet
Postby Krisidious » Fri Nov 30, 2007 4:35 am
yes it works for me...
let me e-mail Didier...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby juju » Fri Nov 30, 2007 4:35 am
what I do is to create the site plan in my CAD software, then import it into SU and do a terrain model from that
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
juju
Premium Member
Premium Member
Postby Krisidious » Fri Nov 30, 2007 4:36 am
Didier must be on vacation or something...
let me make this bigger.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby not registered yet » Fri Nov 30, 2007 4:37 am
Hey Kristoff,
This is in reference to the link u posted:
There are a lot of awesome tools here that i really could use but every time i click on one of the links it directs me to a page containing the ruby script.... i could copy this into a text editor but how do i convert that into a ruby script?! I really dont know much about scripting so i'd really appreciate it if u could clear this one out fer me...
Thanx a million!!
P: iamjerine
not registered yet
Postby boofredlay » Fri Nov 30, 2007 4:37 am
Right click on the ruby script and save target as...
Save it here:
C:\Program Files\Google\Google SketchUp 6\Plugins
Then open SketchUp and start using your Rubies. Really simple.
Cheers.
boofredlay
Global Moderator
Postby juju » Fri Nov 30, 2007 4:38 am
be sure not to save a ruby script in apps like MS Word or the like since they add formatting and basically render the ruby useless. if you feel you have to open and edit something, do so with an app like notepad (simple text editor).
juju
Premium Member
Premium Member
Postby not registered yet » Fri Nov 30, 2007 4:38 am
oh hey im sorry i think i dint xplain the problem clear enough.... the thing is wenever i click on any one the links to rub scripts in "http://www.crai.archi.fr/RubyLibraryDep ... c_page.htm" it directs me to a page wich contains just text.... so after i copy all this text onto notepad how do i convert it from a ".txt" file to a ".rb" file before i copy it into the plug-ins folder?!
thanx again!!
P: iamjerine
not registered yet
Postby Gaieus » Fri Nov 30, 2007 4:39 am
Simply just save as "rubyname.rb" i.e. just type the .rb extension after the name of the ruby (always save the ruby with the same name it originally has for it needs to get loaded and at the end of the script it even refers to this name).
Postby not registered yet » Fri Nov 30, 2007 4:40 am
awesome dude!!! thnx a ton man!! i think im gona hav a looott of fun now that i know that!! thnx again! :D
P: iamjerine
not registered yet
Return to Newbie Forum
Users browsing this forum: No registered users and 6 guests
