look at face
The ideal place for beginners to get help using SketchUp
look at face
Postby dammerel » Fri Nov 30, 2007 4:20 am
hi all
While modelling, can you pick a face and "look at" it ?
also what would be the best way to draw a series on hole on a diameter (P.C.D)
Andrew
dammerel
Re: look at face
Postby Gaieus » Fri Nov 30, 2007 4:20 am
Andrew,
1) if you mean whether you can align your view to a face easily then yes. Right click on it and select "align view". this will orbit the camera perpendicular to the given face (now this does not work with curved faces though).
2) I don't understand your question, sorry.
Re: look at face
Postby Jean Lemire » Fri Nov 30, 2007 4:23 am
Hi folks.
See attached SU file for ideas.
Note that this model is not drawn to any specific measurement but is given solely as an example.
Holes rotation.skp
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Jean Lemire
Global Moderator
Re: look at face
Postby dammerel » Fri Nov 30, 2007 4:24 am
PCD is like bolt holes around a tyre rim..
sorry Im a mech. eng !
dammerel
Re: look at face
...and thanks for the answer
Andrew
dammerel
Re: look at face
Postby nomicrowave » Fri Nov 30, 2007 4:25 am
Hi Andrew,
I use the camera menu a lot. Camera, Standard Views, then pick which view you need. It's a quick and easy way to get to the side you need to see.
Nomi
nomicrowave
Re: look at face
Postby dammerel » Fri Nov 30, 2007 4:25 am
thanks I actual think thats just as easy..Andrew
dammerel
Return to Newbie Forum
Users browsing this forum: No registered users and 8 guests
