How replace material & remove material from edge ?
The ideal place for beginners to get help using SketchUp
Postby Daryan » Tue Dec 15, 2009 2:17 am
Hi all,
- How can i remove all material from all edge of the modele (edge only, not face) ? Is there a plugin for that ?
- How can i replace a material by an another in all the modele ? Is there a plugin for that ? Right clic, select, select all face with same material doesn't work beacause there is a lot of group and component.
Thanks by advance for your help.
Daryan
Re: How replace material & remove material from edge ?
Postby TIG » Tue Dec 15, 2009 10:44 am
Switch to Wire-frame Mode so that only Edges are now visible,
Select the Edges to be changed,
Set the current Material to <Default> in Browser,
Paint Selected Edges with it.
To check their Material - use Entity Info -
[Note that you can also change their Material in this dialog too]...
Global Moderator
Postby Daryan » Tue Dec 15, 2009 1:54 pm
Realy good idea, i never think to use the Wire-frame mode. But i have a lot of group and component (more than a thousand), and i want to cleanup the Edge material, because they prevent me to purge unused material.
Daryan
Postby TIG » Tue Dec 15, 2009 2:14 pm
This viewtopic.php?p=96863#p96863 will change or remove materials from selected items too...
Global Moderator
Postby Daryan » Wed Dec 16, 2009 2:31 am
Your plugin is perfect, thanks a lot !
[Topic resolved]
viewtopic.php?f=323&t=17587&p=140672&hilit=[Plugin]#p140672
(the plugin doesn't work for component but it's a good start).
(the plugin work perfectly).
Daryan
Return to Newbie Forum
Users browsing this forum: Google Bot and 4 guests
