Converting a model to a solid
The ideal place for beginners to get help using SketchUp
Postby Baker518 » Fri Nov 30, 2007 2:30 am
I created a piece that has turned out hollow, NOT solid. How do I make it a solid?
Thanks....Mike
Don't worry about things you have no control over. Worry is a lack of Faith!
Baker518
Re: Converting a model to a solid
Postby baz » Fri Nov 30, 2007 2:30 am
better post the skippy mike. not nearly enough info to comment.
baz
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby Baker518 » Fri Nov 30, 2007 2:32 am
Here is the smaller file of the 3.
Top Connector.skp
Baker518
Postby boofredlay » Fri Nov 30, 2007 2:32 am
Mike, SU does not create solid objects. Only the appearance of solid objects. There is a ruby script that will help give the appearance even more called sectioncutface. You can find it here: viewtopic.php?f=153&t=1517
Right click on the section plane and select Add Section-Cut Face. It will create a plane at the section.
Hope this helps.
boofredlay
Global Moderator
Postby Baker518 » Fri Nov 30, 2007 2:37 am
That didnt work so great, oh well. It was worth a shot
Thanks for the help...Mike
Baker518
Postby boofredlay » Fri Nov 30, 2007 2:38 am
What did not work? The script or the fact that it is not a solid?
boofredlay
Global Moderator
Postby Baker518 » Fri Nov 30, 2007 2:38 am
Eric
Sorry I didnt get back to you on the solid, but it worked but not the way I wanted it to. I think something like even a hatch of some sort would be ok, but I dont know how to do it.
Baker518
Return to Newbie Forum
cron
