Adjust a Section Plane
The ideal place for beginners to get help using SketchUp
Postby rhankc » Fri Nov 30, 2007 2:11 am
The Section feature includes the far extents of anything that is on my screen, and I want to limit its field of spread.
I am trying to figure out how to adjust the section plane in the cut dimension. There is a floor plan that I am showing as a section and the adjacent roof is getting cut about mid height. I want to move the section plane boundry to the edge of this roof so it shows in whole and the floor plan at the same height shows sectioned.
I'll delete the pic later.
Hank
rhankc
Re: Adjust a Section Plane
Postby Edson » Fri Nov 30, 2007 2:11 am
i am not sure i get what you want to do. if you raise the section plane you will see more of the roof and less of the plan. maybe you have to work with 2 section planes.
please elaborate on your description. perhaps a sketch would help.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby rhankc » Fri Nov 30, 2007 2:12 am
It is a horizontal plane, and yes if I raise it (the plane) the roof will show but I will loose the cut at the optimum location on the walls: showing the windows and stuff I want to see..
I want to push the boundary of the section plane to the division line, where the roof wont be getting cut but the floor plan will.
ThX
Hank
rhankc
Postby rhankc » Fri Nov 30, 2007 2:13 am
The boundaries of my sections are acres wide
Hank
rhankc
Postby Edson » Fri Nov 30, 2007 2:14 am
if you make your building into a group, edit the group and then place the section plane it will have its width restricted to the width of the building. if you do not do that the section will be as wide as your model.
i suggest you watch these two very good videos on sections, one by go-2-school, the other by aidan chopra. and there are two more by chopra here.
have fun.
Edson
Global Moderator
btw, what do you use to get the ripped off look to your images posted here?
Edson
Global Moderator
Postby rhankc » Fri Nov 30, 2007 2:15 am
Exactly what I was needing...thank you Edson. I just have to set a new section...that portion is already a group. thank you Edson.
The screen shot is made by a real functional tool called Snagit 8 (http://www.techsmith.com/). I tried practically every screen tool available when my laptop didn't have a screen tool in it. This one has so many tricks, it is well worth the price...after you use up the free full functional trial ..of course. and no, they don't pay me to say that.
Hank
rhankc
Edson,
Also, thanks for the links to the video tutorials. Very good...
Hank
rhankc
Return to Newbie Forum
Users browsing this forum: No registered users and 6 guests
