Array Copy along Edge?
The ideal place for beginners to get help using SketchUp
Postby thomthom » Wed Nov 28, 2007 1:33 pm
Can it be done? In SU itself or with the help of an extension?
I've used to model in 3DSMax and there's a tool there that let you do this and it's such a great timesaver.
PluginStore Author
PluginStore Author
Re: Array Copy along Edge?
Postby Gaieus » Wed Nov 28, 2007 2:08 pm
Tom,
Have a look at the SU Guide here (go down to about 2/3 of the page to see "Linear arrays").
Also, "Radial arrays" are worth to have a look at here (somewhere in the middle of the page).
Then here is a tut by Eric about similar issues and finally if your path is neither a single line nor a circle (arc) but something irregular, there's "pathcopy.rb" by Rick Wilson (RickW here) that you can download either from their site, Smustard.com of from Didier Bur's Ruby Library Depot.
Cheers
Postby Howard leslie » Wed Nov 28, 2007 2:27 pm
Thomas,
I've produced a quick tutorial for you here:
viewtopic.php?f=22&t=2073
Hope this helps
Howard L'
Howard leslie
Postby thomthom » Wed Nov 28, 2007 3:26 pm
Thanks for your responses. Sorry that I wasn't very specific with my question, but I was referring to copy along an irregular edge. I was aware of the linear array copy.
I tried the ruby plugin, however I can't get it to work as I expect. The path is a set of connected lines, but the plugin won't let me select all the elements when it asks me to pick a path. It only uses the first segment I click on. preselecting the path doesn't do it either. Grouping the path segments is also a no go. Are they meant to be joined somehow? I've not found any command in SU to join connecting lines.
Any ideas?
PluginStore Author
PluginStore Author
Postby Marek Badzynski » Wed Nov 28, 2007 3:45 pm
Thom,
try the WELD ruby for "welding" line pieces together. Then you can select a whole(long) path for your copy-along-path
Weld.rb is free - I think smustard has it
Marek
Marek Badzynski
Postby Gaieus » Wed Nov 28, 2007 3:46 pm
Tom,
again a nifty little ruby; "weld.rb" will be of your help. You can download it from Didier's site here again.
It will (well) weld any segmented lines back to one polyline. You can also use it for re-welding exploded arcs, curves etc. Just pre-select what you want to weld and run it. In this particular case of course don't check "close curve" etc.
Postby thomthom » Wed Nov 28, 2007 4:13 pm
Just what I needed! Thank you very much!
Is there a way to set where it begins the first object?
...maybe I can just break the spline..? I need to play around with this.
PluginStore Author
PluginStore Author
Postby thomthom » Wed Nov 28, 2007 4:16 pm
Got it working as I want now. Thanks again for your help.
PluginStore Author
PluginStore Author
Return to Newbie Forum
Users browsing this forum: No registered users and 4 guests
