curved roads
The ideal place for beginners to get help using SketchUp
curved roads
Postby not registered yet » Mon Nov 26, 2007 2:45 pm
i am trying to make a curved road....cud anyone pls help me...
P: sdhamodaran
not registered yet
Re: curved roads
Postby Gaieus » Mon Nov 26, 2007 2:46 pm
Curved in which direction? Only on the x/y plane or winding uphill (on a TIN terrain) like a snake path?
Re: curved roads
Postby juju » Mon Nov 26, 2007 2:46 pm
I think the best way to do this is to create a contour plan (showing indent/protrution a road will make in the contours) in a CAD package, save it as a DWG file, import into SU, layer the contours onto the various levels (depends on the contour increments used) and use the sandbox > from contours function to generate the terrain together with an approximation of the road all in one go.
A good idea is to have a 2D (flat) line drawing of the road lined up in the Z-direction as well. Create a face from it, extrude it through the terrain generated above, intersect with model. You'll now be able to texture the road surface individually (and accurately) from the terrain model.
juju
Premium Member
Premium Member
Re: curved roads
Postby not registered yet » Mon Nov 26, 2007 2:47 pm
ya its part of a bridge whose one part is curved and tapering..
P: sdhamodaran
not registered yet
Re: curved roads
Postby Krisidious » Mon Nov 26, 2007 2:47 pm
SketchUp needs a Spline Command
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Re: curved roads
Postby Gaieus » Mon Nov 26, 2007 2:49 pm
when you have the top view of the bridge as well as the surrounding, I'd suggest you to draw a 2d path for your road and then make a sloped drive of it down the bridge to the road it needs to connect.
I've posted a "tut" about slanted ramps that you might make some use of during the process:
viewtopic.php?f=20&t=627
If stuck anywhere, just come back...
Re: curved roads
Postby not registered yet » Mon Nov 26, 2007 2:50 pm
hey thanks i used the arcs, offset and then push/pull then cut it into a neat bridge .. anyway i will try ur idea... then u can call me dam
P: sdhamodaran
not registered yet
Re: curved roads
Postby Gaieus » Mon Nov 26, 2007 2:50 pm
Only then? I mean Dam
:D
Re: curved roads
Postby not registered yet » Mon Nov 26, 2007 2:51 pm
thats a gud one.. how abt a gtalk... i think it will be more useful atleast for me..
P: sdhamodaran
not registered yet
Re: curved roads
Postby Gaieus » Mon Nov 26, 2007 2:52 pm
Never tried...
msn?
sykpe (gaieus)?
Return to Newbie Forum
cron
Users browsing this forum: No registered users and 5 guests
