The ideal place for beginners to get help using SketchUp
by 3eighty » Mon Nov 26, 2007 1:10 pm
Is there a way to taper a long cyl??? Like an airplane body.
3eighty
by Krisidious » Mon Nov 26, 2007 1:10 pm
yes
create the cylnder...
select the top circle...
select the scale tool...
scale about the corners... should create a cone.
Krisidious
- Name: Krisidious
- Operating system: Windows
- SketchUp version: 2015
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by alan wood » Mon Nov 26, 2007 1:12 pm
Hi guys, I think there were a few people on the old forum who did a teach package on this. I think, one was Jean Lemire who is a member of this forum.
Alan.
alan wood
- Name: alan wood
by Gaieus » Mon Nov 26, 2007 1:13 pm
Hi 3eighty,
Gully's tuts are very intuitive, I'd suggest it to you . I also made a tut about tapering into a non-parallel shape (see it here) but for a fuselage a simple follow me would also do it. However an airplane body is not axisymmetrical (correct my English, Gully, if the term is not correct, please...)
- Name: Csaba Pozsárkó
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
by dylan » Mon Nov 26, 2007 1:13 pm
Again, nice simple effective tut Gulley, good stuff!
Another way to taper a cylinder similar to Kris's method is to highlite the top edge and in the Entity Info box and change the circle radius.
dylan
- Name: Dylan
- Operating system: Mac
- SketchUp version: 2016
- License type: Pro
- Level of SketchUp: Beginner
by Krisidious » Mon Nov 26, 2007 1:14 pm
speaking of that dylan, have you ever wished you could change the square footage manually, by typing in that info box?
Krisidious
- Name: Krisidious
- License type: Pro
by 3eighty » Mon Nov 26, 2007 1:14 pm
As always a BIG thank you to you all...Off to play now..
3eighty
by dylan » Mon Nov 26, 2007 1:14 pm
krisidious wrote:speaking of that dylan, have you ever wished you could change the square footage manually, by typing in that info box?
I have never actually thought of that, but now you mention it..
dylan
- Name: Dylan
- License type: Pro
by Krisidious » Mon Nov 26, 2007 1:15 pm
I can never get an acre to be an arce by drawing it. in a square... it's always off just a little in square feet...
if I could type it in that would be great... but then it would have to push it'self out along some edge and chose that edge.
ahhh to wish
Krisidious
- Name: Krisidious
- License type: Pro
by Gaieus » Mon Nov 26, 2007 1:16 pm
I don't have any problem with hectars though (100 metres by 100 metres = 10,000 square metres). Why don't you convert to some more logical measurement units?!
- License type: Pro
by Jean Lemire » Mon Nov 26, 2007 1:18 pm
Hi folks. See attached SU file. This an acre with an error of about 0.0000004 %. Just ideas. Acre.skp
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Jean Lemire
- Global Moderator
- Name: Jean Lemire
- License type: Pro
- SketchUp use: engineering and mechanical design
by Krisidious » Mon Nov 26, 2007 1:18 pm
Gaieus wrote:I don't have any problem with hectars though (100 metres by 100 metres = 10,000 square metres). Why don't you convert to some more logical measurement units?!  from your lips to our goverment's ears... we pray...
Krisidious
- Name: Krisidious
- License type: Pro
by Krisidious » Mon Nov 26, 2007 1:19 pm
yes Jean, that's very good... but you've got your units set to decimal. so it's for some reason much more accurate.
I'm set on imperial... so taking Jean's que...
I took his? drawing... and converted it to imperial. and then it's exactly an acre. or 43,560 sq. ft.
so I guess if an imperial person wants a precise drawing, we need to draw in decimal then convert to imperial....
well thanks for the work around Jean... boy or girl, not sure?
don't take offense, my name is Kris with a K so I know...
Krisidious
- Name: Krisidious
- License type: Pro
by juju » Mon Nov 26, 2007 1:20 pm
Looking at the signature it reads "(Johnny)" so I guess Jean is male and not female then.
juju
- Premium Member
- Name: Juju
- SketchUp version: 2019
- License type: Pro
by Jean Lemire » Mon Nov 26, 2007 1:21 pm
Hi folks.
Yes, I use Johnny with my English speaking friends.
Jean is the french for John.
Jean Lemire
- Global Moderator
- Name: Jean Lemire
- License type: Pro
- Robot
Return to Newbie Forum
