Closing Groups and Components after edit
The ideal place for beginners to get help using SketchUp
Postby rhankc » Mon Nov 26, 2007 12:18 pm
Is there a command to close multiple groups and components with one click or menu selection?
I am working on this house, and I have deep levels of groups and components, when I need to make a minor adjustment to an deep lying entity, that is like ten levels down i want to get back out quick and I have to close each instance. is there a command to close all real fast? I see the close group/component under the Edit menu, but this is a one-at-a-time command.
thanks
Hank
rhankc
Re: Closing Groups and Components after edit
Postby Archi Rag » Mon Nov 26, 2007 12:19 pm
u could always keyboard shortcut it (i use 'end') but i guess ur still tapping the same button u can also click outside the component to get out of the grup/component ur editting
i know it doesnt quite answer the question but its a bit of a solution
Archi Rag
Postby not registered yet » Mon Nov 26, 2007 12:19 pm
The top-level object listed in the Outliner (Window > Outliner) is the file name of the model. Just click on it and you'll pop all the way out of your nested groups.
-Gully
not registered yet
Postby rhankc » Mon Nov 26, 2007 12:20 pm
thank you gully
Hank
rhankc
Postby Krisidious » Mon Nov 26, 2007 12:20 pm
yes what gully said, and don't forget to use your layers too... a quick way to turn off areas just so you can work deeper without being in groups and components
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby kdjanz » Mon Nov 26, 2007 12:21 pm
Actually, you don't have to go to the top of the outliner - just click in any white space and it will take you out to the top.
Kelly
kdjanz
Return to Newbie Forum
