Softening a cut
The ideal place for beginners to get help using SketchUp
Softening a cut
Postby miikka1978 » Sat Jun 15, 2019 8:59 pm
Do you have any idea how to make "soft cut"? I would need to cut a hole to the geometry and I would need to make the edges of the cut geometry soft/round because the object will be 3d printed.
This is something I would like to achieve:
miikka1978
Premium Member
Premium Member
Re: Softening a cut
Postby Dave R » Sat Jun 15, 2019 9:29 pm
For whatever reason, your images haven't uploaded. Best bet, though is to upload the SKP file so we can see what you are trying to accomplish. Please also complete your profile with SketchUp version and operating system. That information helps us help you.
User avatar
Global Moderator
Re: Softening a cut
Postby miikka1978 » Sun Jun 16, 2019 4:39 am
New try with the pictures. I don't know what happened with the links.
Now the original post also includes example of the model. Unfortunately I am not able to upload the actual model because it is not my own model.
The attached example of of the model is quite low poly but I in the final model I would need to make the model high poly in order to have nice and smooth 3D printed object.
I also updated my profile a little. I am still using 2017 Sketchup Make.
miikka1978
Premium Member
Premium Member
Re: Softening a cut
Postby Dave R » Sun Jun 16, 2019 10:51 pm
I think the best approach would bt to draw the shape of the hole including the rounded edge and use the whole thing as a drill to cut the hole.
User avatar
Global Moderator
Re: Softening a cut
Postby rv1974 » Mon Jun 17, 2019 4:04 am
Start it flat, then conform it via flowify
rv1974
Re: Softening a cut
Postby HornOxx » Mon Jun 17, 2019 7:11 am
Hi, might not be a SubD approach also be suitable for this? Finally you could remain in a simple base geometry, similar to this (unfinished!) proxy-sketch below...
never trust a skinny cook
User avatar
HornOxx
Re: Softening a cut
Postby mrossk » Mon Jun 17, 2019 3:43 pm
Some time ago, Jeff Hammond did a great example using Curviloft to do just such a thing. the video is here: http://www.youtube.com/v/gy5VGSxST2Q
In the same thread, others posted some other options. Worth a look: viewtopic.php?f=15&t=46136&p=412551&hilit=curviloft#p412551
mrossk
Re: Softening a cut
Postby miikka1978 » Tue Jun 18, 2019 4:22 am
Thanks for everybody for suggestions/tips. I will need to do some testing.
I was also thinking that maybe I will try to take the created geometry to Blender and test if I can use Blender for making the whole with soft edges.
miikka1978
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: mattazpi10 and 4 guests
Visit our sponsors:
