Minimum wall thickness?
The ideal place for beginners to get help using SketchUp
Postby RBarone » Wed Jul 18, 2012 11:09 am
Anyone know of a plugin that highlights a preset minimum wall thickness for 3d printing?
For example if i set a minimum wall thickness to 3mm it would check the model and point out anything less than the minimum?
I am getting pretty good at Sketchup and have downloaded many plugins already. But maybe Sketchup do it already and I am just not seeing it?
RBarone
Premium Member
Premium Member
Re: Minimum wall thickness?
Postby TIG » Wed Jul 18, 2012 1:46 pm
I Xray mode you can see the inside and outside of a solid object's "shell".
You can then pick points with the TapeMeasure tool and get the distance == thickness...
Also cutting sections lets you see inside objects and do similar measuring...
User avatar
Global Moderator
Postby RBarone » Sat Jul 21, 2012 11:55 pm
TIG wrote:I Xray mode you can see the inside and outside of a solid object's "shell".
Thanks TIG. Much appreciated.
RBarone
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Bing [Bot] and 9 guests
Visit our sponsors:
