Leaks! How to identify their location in SU8
The ideal place for beginners to get help using SketchUp
Postby babycody » Sat Oct 02, 2010 10:29 pm
When I try to use the solid tools, I am told that my model has one or more leaks. I am glad that Sketchup found them, but couldn't Sketchup let me in on where they are located? It's like SU is sticking its tongue out at me saying "I know where the leak is, but I'm not telling". Is there a Ruby script that can help identify a leak's position by possible highlighting the surface or line segments where the leak exist? Some leaks are very hard to find.
babycody
Re: Leaks! How to identify their location in SU8
Postby Rich O Brien » Sat Oct 02, 2010 10:49 pm
Welcome to SCF!
Thomthom's 'Solid Inspector' in our plugins forum does exactly what you ask. Just do a search ;)
User avatar
Rich O Brien
Administrator
Postby Gaieus » Sat Oct 02, 2010 10:50 pm
Ah yes, Rich is always faster than me when he does NOT do that search.
And he is Irish as well. :roll:
Here is ThomThom's plugin to find your "leaks":
viewtopic.php?t=30504
User avatar
Postby notareal » Sat Oct 02, 2010 10:54 pm
notareal
Thea Render Support
Thea Render Support
Postby Rich O Brien » Sat Oct 02, 2010 10:57 pm
Oooooooooh.......
Honeymoon over?
User avatar
Rich O Brien
Administrator
Postby Gaieus » Sat Oct 02, 2010 11:01 pm
Ah yes. She is sleeping with a girlfriend in the other room (after a good night of boozing out) and I am left with you guys...
User avatar
Postby babycody » Sat Oct 02, 2010 11:48 pm
Thank you everyone! Especially thomthom for creating this ruby script. That is a great plugin. I had a very small line segment outside of a group, and I was able to easily identify and fix it. Oh, and thank you for the warm welcome. I think I will like it here.
babycody
Postby sarookha » Wed Mar 25, 2015 2:03 pm
Solid Inspector2 is a nice idea, but the very first solid I tried it on returned a message telling me that holes in the mesh cannot be repaired automatically, that I would need to fix the hole first and then run Solid Inspector again. Really??? I thought this is what Solid Inspector was going to help me do in the first place.
My pseudo-solid is a 5 sided beam, one of the simple rectangular sides won't close. I've deleted the offending edges and re-drawn using both pencil and rectangle tools, and of course tried Solid Inspector2. SI2 shows me the offending edges, but can't/won't fix them.
sarookha
Postby slbaumgartner » Wed Mar 25, 2015 4:32 pm
Almost surely SketchUp and SolidInspector are both telling you the same thing: a face can't be created because the corner vertices are not in a single plane. You can quickly confirm this by drawing a diagonal across it. If you get two triangular faces, that was the problem. You will need to fix the vertex locations from the other sides before you can draw a single rectangular face.
slbaumgartner
PluginStore Author
PluginStore Author
Postby TIG » Wed Mar 25, 2015 7:27 pm
Perhaps if you posted the SKP we could comment more constructively...
Sadly thomthom's SolidInspector2 and my own SolidSolver can't perform miracles, just fix schoolboy errors...
There's a limit to every algorithm.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: No registered users and 8 guests
