SketchUcation Plugin Store
Laptop resolution v Monitor resolution
Postby Stu » Sun Nov 18, 2007 3:15 am
If I have a 15.4" laptop with a native resolution of 1400x900 and hook it up to a 22" monitor with a native resolution of 1680x1050 what resolution will I be looking at on the monitor?
The laptop's or the monitor's?
I'm presuming it's the monitor's but some reassurance would be appreciated.
And just to confuse me even further I have just come across a nicely specified 17" Asus lappie for about the same price as a 15.4" + a 22" monitor. Portability isn't a big issue it would be sitting on my desk most of the time :?
Thanks anybody :)
Stu
Stu
Re: Laptop resolution v Monitor resolution
Postby Anssi » Sun Nov 18, 2007 2:38 pm
Stu,
It depends on how you like to configure it. Modern graphics cards ough to be able to support native resolutions on both displays. On a laptop, you also typically have several configuration choices:
- either display can be the primary one, and the other is blank
- the image on the primary display is duplicated on the second one
- your desktop is expanded to incorporate both the displays
Anssi
Anssi
Postby Stu » Sun Nov 18, 2007 9:09 pm
Anssi, thanks,
I sort of get what you are saying.
The laptop's video card will be able to cope with the monitors resolution.....so, to put it simply....if I plug the monitor into the laptop, will the monitor automaticlly configure to its native resolution...or would I need to set it up each time?
And out of interest is anybody regularly using this type of setup?...or will I probably find that I would simply work mostly on the lappie [my first one, and probably a 17"]
Thanks,
Stu
Stu
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Hardware, Software & Gadgets
