SketchyPhysics 3.3 (Unofficial Release)
Moderator: CPhillips
Re: SketchyPhysics 3.3 (Unofficial Release)
Postby ZoltanSpin » Tue Aug 12, 2014 6:13 pm
Hello,
I am using Sketchup 14.1.1282 and Windows 8, all 64bits.
I guess I'm supposed to download/extract into Google/Google Sketchup 8/ plugins and then find there :
Sketchyphysics (directory)
SketchyPhysics.rb (file)
and... just launch Sketchup ?
What else if SU doesn't see Sketchyphysics ?
Maybe I missed something ?
Thank you all for your help, and Anton for his labor.
Zoltan
ZoltanSpin
Postby Anton_S » Thu Aug 14, 2014 6:49 am
You say you have SU 2014, but posted in SU8 plugins folder. SU2014 has its ow plugins folder: C:\Users\UserName\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
Keep in mind this release works on Windows only and has some bugs that I created while rewriting the code. Next release will be better.
Anton_S
PluginStore Author
PluginStore Author
Postby tallbridgeguy » Thu Aug 14, 2014 11:48 pm
Hi Anton, great stuff. Any chance you can enhance the output so that it can be rendered in a program like Kerkythea or Thea or .....
I had a long work around to get it into to Kerkythea but it was a pain to do long animations.
Here is a quick render from Kerkythea using SKPH.
http://youtu.be/rJbZBMN7R4I?list=UU5HQa ... uw-d_Vph4w
Thanks!
s
tallbridgeguy
Postby Anton_S » Fri Aug 15, 2014 12:02 am
I'll look into, but can't promise anything.
Anton_S
PluginStore Author
PluginStore Author
Postby ArturM » Wed Aug 20, 2014 2:00 pm
Anton_S wrote:I need some people to test this on Mac OS X.
Hi, I would like to test on OSX.
Downloaded plugin, and copied to:
/Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/
and
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/
In Sketchup 2013 after start:
Code: Select all
Error Loading File /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/main.rb
no such file to load -- /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/lib/dl
Error Loading File SketchyPhysics.rb
Ruby console is empty.
In Sketchup 2014 Make after start:
Code: Select all
Error Loading File /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb
Error: #<RuntimeError: An error occurred while trying to load Ruby FFI!
cannot load such file -- /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
/Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in `require'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:7:in `<top (required)>'>
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:10:in `rescue in <top (required)>'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:6:in `<top (required)>'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/newton.rb:8:in `<top (required)>'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb:23:in `<top (required)>'
/Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in `register_extension'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in `<module:MSketchyPhysics3>'
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:199:in `<top (required)>'
in Ruby console:
Code: Select all
(eval):1: warning: already initialized constant Traductor::SU_MAJOR_VERSION
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:40: warning: previous definition of SU_MAJOR_VERSION was here
(eval):1: warning: already initialized constant Traductor::RUN_ON_MAC
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:39: warning: previous definition of RUN_ON_MAC was here
MacBookPro 2013, OSX Yosemite (developer preview (i have also 10.9 Maverick on another machine - can test if that helps)).
ArturM
Postby Anton_S » Thu Aug 21, 2014 10:29 pm
Thank you
Anton_S
PluginStore Author
PluginStore Author
Postby RobiBue » Mon Sep 01, 2014 4:20 am
Hi, I'm on Win7 and have SketchUp 14 (free). I downloaded the SketchyPhysics_3.3.0.zip file, installed the files in C:\Users\UserName\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins and can't get it to work :(
One reason - I think - is that I have no "Plugins" menu:
but the main reason stems from the following Load Errors:
Error Loading File C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb
5: Access is denied. - C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:7:in `<top (required)>'>
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:10:in `rescue in <top (required)>'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:6:in `<top (required)>'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/newton.rb:8:in `<top (required)>'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb:23:in `<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in `register_extension'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in `<module:MSketchyPhysics3>'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:199:in `<top (required)>'
can anybody shed some light on this?
RobiBue
Postby Fred_Flintstones » Mon Sep 01, 2014 7:55 am
Seems awkward that you’d start trying to update SP when you were working on a full rewrite…You must have hit a snag (or got bored). Tho I do see how working directly with SP would help, so no complaining here…But you should have posted you were going to do this on the other thread ;)
Fred_Flintstones
Postby Anton_S » Mon Sep 01, 2014 12:11 pm
New update will come today, and well see if it works. Sorry for inconvenience.
Anton_S
PluginStore Author
PluginStore Author
Postby RobiBue » Mon Sep 01, 2014 12:51 pm
Anton_S wrote:New update will come today, and well see if it works. Sorry for inconvenience.
No inconvenience at all :) really glad that SP is being worked on for the newer SU versions. :ecstatic:
Thank you.
RobiBue
Postby Anton_S » Mon Sep 01, 2014 12:59 pm
@RobiBlue According to your log, you have your name as 'UserName' but you should change it to your actual name. If you install SU2014 this path should be automatically created. SU2014 plugins are located in %appdata%
Anton_S
PluginStore Author
PluginStore Author
Postby RobiBue » Mon Sep 01, 2014 2:15 pm
@Anton_S yeah, I changed the name when I posted the log. Assume that the UserName is correct.
I just realized the following entries in the log:
Code: Select all
and therein lied the problem :( Norton AV has some weird "insight WS.Reputation.1" score, which quarantines files it thinks are not safe because not many users have reported it as safe, or the developer didn't submit it to their safe-list https://submit.symantec.com/dispute/insight/ which I have done now.
Sometimes these AV are a PITA but more than that, they save one from a lot of trouble ;)
so far I got SP3.3 working now. :D
Thank you!
RobiBue
Postby Anton_S » Mon Sep 01, 2014 9:06 pm
Very well, although you might want to transfer to SP3.4 : viewtopic.php?f=61&t=58936
Anton_S
PluginStore Author
PluginStore Author
Previous
Return to SketchyPhysics
