SketchUcation Plugin Store
SketchyPhysics3.2 (Dec 2)
Moderator: CPhillips
Re: SketchyPhysics3.2 (Dec 2) UI
Postby bossdave » Tue Dec 28, 2010 3:09 am
I am running SU8 with wine on Ubuntu with SP3.2. The UI box appears showing: Joint, State, Properties, Shapes , but no details. Same problem withSP3.1. Any ideas what I am missing? Thanks
bossdave
Postby phy » Tue Dec 28, 2010 3:59 am
bossdave wrote:I am running SU8 with wine on Ubuntu with SP3.2. The UI box appears showing: Joint, State, Properties, Shapes , but no details. Same problem withSP3.1. Any ideas what I am missing? Thanks
There you go http://forums.sketchucation.com/viewtopic.php?f=61&t=33030
webdialogs don't work in wine without this tweak.
Have A Good Day! ;)
phy
Postby CPhillips » Wed Dec 29, 2010 9:26 am
jblively wrote:- New script command setFrameRate overrides physics settings framerate.
Hello, trying to implement the set frame rate command to get the model to slow down on faster computers so we can anticipate the results.
Can you let me know the usage and where to put it.
I've tried setFrameRate=5; in the on tick section and it doesn't seem to make any difference.
Thanks,
Joe
Thats not quite how it works. a frame rate of 5 will make the physics simulation step 5 times before updating the sketchup model. To make it go a little slower you could use a frame rate of 1.
CPhillips
SketchyPhysics3.2 (Dec 2) ui not working
Postby robint » Tue Jan 04, 2011 10:54 am
help UI window not working
Postby robint on Mon Jan 03, 2011 8:59 am
ive got su8 latest and sp 3.2 installed
when I try to inspect joints i get the usual info for a hinge (say). when I try to input say accel or a controller name , it accepts them but doesnt do anything - no slider in the run panel
Ive tried the other tip of clicking on the UI button to exit the UI window to no avail
I saw a tuorial where it said that you can turn a hinge into a reversible motor by putting accel = 1 and giving the controller a name - which is then supposed to bring up a slider in the run panel - i just get a blank.
then i go back and look again and just get blank boxes. only restarting su8 will clear the prob but it comes back if I try to change a parameter
cheers Robin
ps I havent got so excited since I first used SU4 - this could be a wonderful educational tool if physical values could be added to demonstrate newtons laws for example
I made a double pendulum the other day, but as already said, there's lots of real world physical attributes to be addressed (eg mass, density, friction, elasticity etc) but its early days
robint
Postby robint » Wed Jan 05, 2011 11:21 am
Hi guys
how or where do I post a skp model for discussion
also i cant post a link here?
robin
robint
Postby robint » Thu Jan 06, 2011 9:21 am
This site seems to be moribund, not a lot happening?
Anyway Ive solved the UI problem
so all working ok now
robint
Postby robint » Thu Jan 06, 2011 9:31 am
here my 2c worth for sp 3.2
if you want to make a reversible motor joint, use the hinge (as per sp2) and set the controller blue box to
quote slider ( 'anyname' )
you can see the same construction using the motor joint
wish I didnt have to waste hours getting to this point.
Also
to make magnetic solids work you need to set the ui box status to magnetic
and the magnetic force to a large value eg +- 1000
not obvious is it?
I wonder whether its worth contributing to a wikimanual at5 this stage if thereis going to be an sp4 completely recoded?
Robin
robint
Postby jblively » Fri Jan 07, 2011 2:45 am
robint wrote:to make magnetic solids work you need to set the ui box status to magnetic
I do believe that magnetic force is also affected by mass and scale. So if the model is very large, you'll need a larger value for magnetic force. If you have a small scale model, you can use a magnetic force of as little as 10 to see results.
There is so much involved in SP, more documentation would be nice, but i'm just glad we have people here we can chat with who want to help!
jblively
Postby Pilou » Fri Jan 07, 2011 3:25 am
Does this vervion can works on the V6?
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free
SketchUp use: hobby
Level of SketchUp: Advanced
Postby robint » Fri Jan 07, 2011 10:06 am
Hi JB
good point
afik though there is a density coeff, I dont know how well it correlates to the mass of an object?
the apparent mass i governed by the size of the collision shape as set in the rt click physics setting
havent figured this tiresome details out yet
I have a number of cu4rious physical models i would like to post for discussion (eg double pendulums etc) but havent yet found a way to post these little experiments.
It seems daft that one cant attach these on this forum - severly limiting
Any ideas?
robint
Postby CPhillips » Tue Jan 11, 2011 3:42 am
Yes magnets are effected by the size of an object.
You can attach files to posts. Look at the bottom of the form and there is an "Upload Attachment" tab.
CPhillips
Postby robint » Tue Jan 11, 2011 10:19 am
hi all
sorry pardon didnt see the tab for uploading
I was trying to make a chain rotating around 2 sprockets. The chain seems to want to fly apart, its all chaotic? even though its all supposed to be stationary, any ideas
btw i have su8 and sp3.2 dec2010
its all good fun but i wish i had more control over the way things work, bit hit and miss at the moment
btw although bugsplat is a good tool, i dont connect my main machine directly to the net for obvious security reasons, so cannot utilise bs directly. It would be much more convenient if bs made a composite text file stored conveniently which i could gather up and post here to help with su crashes. Its a bit cumbersome at the moment
cheers robin
robint
Postby TIG » Tue Jan 11, 2011 11:39 am
CPhillips
Please see here for an 'issue' with group.definition viewtopic.php?p=300105#p300105 ;)
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby robint » Wed Jan 12, 2011 4:26 am
hi CP
thanx for the tip, will see if i can make it so.
any pointers on where to start on Ruby so i can at least know something of what im doing?
cheers
Robint
robint
Postby robint » Sat Jan 15, 2011 8:33 am
TIG wrote:CPhillips
I tried the code but it seemed to make things worse
Code: Select all
class Sketchup::Group
if not Sketchup::Group.method_defined?(:definition)
def definition() # make it so you can use group.definition
return(self.entities.parent)
end#if
something about a chain sp doesnt like
Im stuck, my chain flies apart
robin
robint
Postby robint » Wed Jan 19, 2011 9:43 am
High CP
I have used Poser 5 in the past and learnt about inverse kinematics and joints
I think there is a fundamental limitation that prevents you making a chain of joints because the last child joint has to join the first parent so the parent must then become a child. This would be inherently unstable (like positive feedback) which is why the joint flies apart in pieces
Can anyone confirm my guesswork or poiont me somewhere that a working chain has been made (ie will revolve around a sprocket
cheers robin
robint
Postby hpnisse » Wed Jan 19, 2011 4:47 pm
Hey, robint!
Your chain works perfect when you set the collision state correct in every single object :D
Re. my chain 1.skp
/hpnisse
Windows 7 U - Sketchup 8 - SketchyPhysics 3.2-Dec2 - from Sweden
hpnisse
Postby Oxer » Thu Jan 20, 2011 3:21 am
I have installed SketchyPhisics 3.2 on Mac with OSX 10.6.6 and SU8 and the plugin don't woks, SU read the plugin, appear the toolbars, you can create the shapes but when you press the play appears a window with this message:
Error initializing the Simulation: : uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in `initialize'
And in the ruby console this:
String doesn't compile: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds#<NameError: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds>
/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in `new'
/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in `initialize'
/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in `new'
/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in `startphysics'
/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1650:in `physicsTogglePlay'
/Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1738
I have reinstalled SketchyPhysics3.1 and works.
http://www.oxervision.blogspot.com/
Oxer
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby robint » Sat Jan 22, 2011 2:36 pm
hpnisse wrote:Hey, robint!
Re. my chain 1.skp
Hi H
Thanks for that tip, the model chain works for me now, but I dont understand how setting the object state to "show collision geometry" makes such a radicle difference?
obviously i dont understand this state? I looked on the tutor manual but that wasnt helpful
so i am puzzled
nice that one can actually make a set of revolving links
What we need now is a workable spring (with variable rate and damping). the legacy one only works in sp2.3 not in 3.2. perhaps its work in progress
can anyone tell me if joints have a built in friction?
A simple pendulum will slowly come to rest, so there must be some restraint or energy loss built in? is this variable?
in mechanical systems you need mass, stored energy (spring) and friction (damping) preferably using SI units so as to start physical modelling
BTW I was once involved with a brilliant guy who made an amazing music generating prog that allowed exploration of scales, rhythms etc. BUT he was a C++ script magician and his prog became a tangle compost heap of widgets with a poor and almost unusable manual. I tried to help sort out the mess but the guy simply couldnt organise his thoughts in a consistant and methodical manner so his brialliant concepts came to nought as prospective users lost enthusiasm and gave up.
If anyone is preparing to organise a proper manual for SP4 then I can offer my 2c worth
cheers
Robin
All good stuff as I had come to a brick wall till now
robint
Postby robint » Thu Jan 27, 2011 9:33 am
hi all
Im posting some models that illustrate some points and queries
all comments gratefully received
Robin
robint
Postby solodown » Thu Jan 27, 2011 12:42 pm
Toujours pas de nouvelles pour faire fonctionner ce plug-in sous Mac OS X 10.5.8 avec Google SketchUp ?
solodown
Postby zunkian » Thu Feb 24, 2011 4:32 am
Hi!
Is there a manual for SketchyPhysics for beginners?
If there is one, please upload.
Thank you.
Andy
zunkian
Postby dereeei » Fri Mar 04, 2011 4:55 pm
Indeed a user manual for users that did not used ketchyPhysics before would be nice. I noticed that some beginners tips are to be fond here http://sketchyphysics.wikia.com/wiki/SketchyPhysicsWiki , but I'm sure that version 3.2 have much-much more features than are detailed there.
Thanks.
dereeei
Postby 4dHans » Mon Mar 14, 2011 9:41 pm
Could you do like explosions in a future version? That would be cool! :ecstatic:
4dHans
Postby mickeyao » Fri Apr 22, 2011 5:09 am
MBP with 10.5.8 Thanks!
mickeyao
Postby sketchyKev » Fri Apr 22, 2011 10:35 am
robint wrote:hi all
Robin
For the first one (rotating cone) you can make the motor reversible by changing the controller code to (slider('motor8055')-0.5)*2
Using that code the middle position of the slide control is off, full left turns one way and right turns the other way.
For the second one, to create a lift capsule do this:
Create a solid floor.
Place a wheel capsule with built in hinge on the floor.
Place a lift capsule with built in slider on the floor.
Using the JCT click on the hinge joint, then ctrl-click on the slider.
A menu pops up asking if you want to "Create a worm gear..". Click "OK".
Run the simulation and turn the hinge capsule clockwise and the other capsule should rise.
You can build a lift from scratch from components. Just make sure each joint is grouped with the moving objects and joint connected with something static before trying to make the worm gear connection.
For the record a slider is not a piston with the accel and drag values set to zero. A piston with those values will not move.
For the rotating box using a slide controller on a hinge, the program does not recognise a controller called "speed" so it has defaulted to servo behaviour. You can get the same behaviour from a servo by setting min=-180 and max=180. It is known that servos behave badly if you try to get them to complete full circles or more than one circle. There is no need to mess with the hinge controllers as servos and motors are provided.
For the box on a spring, the spring is orientated vertically and does not allow sideways movement or rotation. When you try to drag the box the drag action defaults to horizontal movement. To pull the box up or down inline with the spring you need to hold left-shift on your keyboard while dragging with the left mouse button. Try the spring orientated sideways and it should work fine. The springs are on the stiff side so it is worth playing with the accel and damp settings.
Hope that helps.
sketchyKev
Again ??!!??
Postby Alainbo » Sun Jan 15, 2012 10:39 pm
There are months now that sketchyphysics 3.2 installs 3.1 !!!
Don't understand this update !?
Alainbo
SketchUp version: 8
License type: Pro
Postby bouleaux » Thu Jan 19, 2012 7:20 pm
Hello,
congratulations for this marvellous job !
I'm using sketchup 8 on a Mac Book Pro running on Mac Os 10.5.8
and I would loooove to be able to use sketchyphysics with this computer
any chance ?
thx again
bouleaux
Name: Sébastien Assouline
Postby Oxer » Fri Jan 20, 2012 2:14 pm
bouleaux wrote:Hello,
any chance ?
thx again
Hi, bouleaux
I'm a mac user too, the last version 3.2 doesn't work on Mac but the 3.1 version works fine on OSX Leopard with SU 8.
I hope this help you.
Oxer
SketchUp version: 8
License type: Pro
Postby bouleaux » Thu Jan 26, 2012 11:31 pm
Hello Oxer, many thanks
I tried to find the 3.1 version, but it doesn't seem to be available for download anymore (on this page : http://code.google.com/p/sketchyphysics/downloads/list)
Do you know of another place to find it ?
Thank again for your answer
bouleaux
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Next
Return to SketchyPhysics
Users browsing this forum: Bing [Bot] and 1 guest
