SketchUcation Plugin Store
SketchyPhysics 3x June 27 version.
Moderator: CPhillips
Re: SketchyPhysics 3x June 27 version.
Postby CPhillips » Thu Jul 09, 2009 12:44 am
Here is another useful script. It allows scripts to print text to the screen. In this case a log of whatever touches the floor.
Code: Select all
   #add blank text to screen at 10,50
@@log=SketchyPhysics::addWatermarkText(10,50,"")
   #place to store lines
@@lines=[]
ontouch{|t,s,p|
      #add new line
   @@lines.push(t.name+" touched "+self.name)
      #ensure only 5 lines on screen at once.
   @@lines.shift if @@lines.length>5
      #display lines
   @@log.text=@@lines.join("\n")
onend{
   @@log.erase!
   @@lines=nil
CPhillips
Postby JaViXP » Sat Jul 11, 2009 3:08 pm
Very nice script! :thumb:
Can we upload with this version if we don't use the new features? ;)
"Giving up is way harder than trying"
JaViXP's Rendering
JaViXP
Postby =Physicsguy= » Sun Aug 09, 2009 5:56 am
Never really got back to this one: Are we going to be able to set an object's scripting from an external source code?(ie setting an emitted object to explode on impact.)
=Physicsguy=
Postby JaViXP » Sun Aug 09, 2009 12:50 pm
Nice question, what do you want it for? ;)
Something like this should work (this one doesn't work, just play around with it):
Code: Select all
ontouch{|toucher,speed,pos|
   if(toucher.name=="box"){
      split(self,1)
Hope this helps! :)
JaViXP's Rendering
JaViXP
Postby Wacov » Sun Aug 09, 2009 1:11 pm
=Physicsguy= wrote:Never really got back to this one: Are we going to be able to set an object's scripting from an external source code?(ie setting an emitted object to explode on impact.)
Any SU ruby would work, ao you might be able to load an external .rb file as an ontick func, or whatever. But you don't need that to do what you're asking, as Jav has shown; and anything that SU can detect can be acted upon.
Wacov
Postby CPhillips » Sun Aug 09, 2009 10:48 pm
Hi everyone. Sorry I have been quiet lately. Been taking some time off and enjoying the summer.
I think it is possible to set events externally with this version. I know the the syntax is a bit weird and I plan to clean it up.
Create a good sized cone and put this in its scripted field.
Code: Select all
b=copy
b._setEvent("ontick",
<<CODE
   push([0,0,1])#go forward
   if(frame>50)
      destroy #die after 50.
CODE
The cone will copy itself and then set the "ontick" event in the copy.
I tried to make an example that uses "ontouch" but it didnt work for some reason. I will have to debug it.
CPhillips
Postby NorviewsVeteran » Thu Aug 20, 2009 8:05 am
Sorry I don't have much to add, but there are a few things. I'm no programmer, I'm on the mechanical team.
1. You guys are blowing my mind. Wacov, when I opened your cloth file my jaw dropped for so long I almost drooled on my cat.
2.
3. I needed an excuse to upload the Gopher.
Code: Select all
//This_Is_All(I)+=Know()About.Code;
NorviewsVeteran
Postby CPhillips » Fri Aug 21, 2009 6:06 am
Nice model!
CPhillips
Postby NorviewsVeteran » Sat Aug 22, 2009 7:00 am
Thank you, have another.
I figured out the scripted joints (big for me) to the point where I used universal joints for the bogies and you can copy more cars to the train, but the problem is I had to daisychain the joints under the cars so much the sag makes the cars lean in turns. Just beware of derails, they seem to be quite frequent...
If anyone can figure out a way around this, that would be great.
Code: Select all
NorviewsVeteran
Postby Wacov » Thu Aug 27, 2009 6:41 pm
NorviewsVeteran wrote:1. You guys are blowing my mind. Wacov, when I opened your cloth file my jaw dropped for so long I almost drooled on my cat.
:roflmao:
CPhillips wrote:I think it is possible to set events externally with this version. I know the the syntax is a bit weird and I plan to clean it up.
Code: Select all
b=copy
<<CODE
   if(frame>50)
CODE
It totally crashes my SU when I try it in ontouch, and freezes the sim in ontick... also, I can't drag the original object. It highlights, and the drag line appears, but no movement :?
Wacov
Postby =Physicsguy= » Thu Aug 27, 2009 7:52 pm
Err... looks like you didn't try it in the right field.
=Physicsguy=
Postby Wacov » Fri Aug 28, 2009 3:17 pm
I mean ontick/touch as in:
Code: Select all
ontick{
Try it, see what you get.
Wacov
Postby CPhillips » Fri Sep 04, 2009 11:55 pm
I am not 100% sure that works in this version. It may depend on some unreleased code. Can anyone confirm it works?
CPhillips
Postby =Physicsguy= » Sun Sep 06, 2009 2:20 am
It works for me.
=Physicsguy=
Postby JaViXP » Sun Sep 06, 2009 2:44 pm
Same for me.
JaViXP's Rendering
JaViXP
Postby Wacov » Sun Sep 06, 2009 4:02 pm
It works for me, just not in any events.
Wacov
Postby CPhillips » Sat Sep 12, 2009 5:46 am
Wacov wrote:It works for me, just not in any events.
Not sure I understand. Can you post a model that fails and I will take a look.
CPhillips
Postby =Physicsguy= » Sat Sep 12, 2009 6:36 am
BTW,(this may be a stupid question), but is there a way around the camera 'bending' situation where the camera eye overshots to some other point3D? I cant get any reliable camera systems...
=Physicsguy=
Postby Wacov » Sat Sep 12, 2009 12:01 pm
In Jun 27, putting your code inside a normal event (ontick{...}) crashes. It seems to work in the SVN version, though :?
Wacov
Postby mariocha » Thu Oct 22, 2009 3:11 am
Hi, just to share 2 small animations done with SkPh-3.
One is quite amusing, showing Emitter, Thruster and magnet
http://www.youtube.com/watch?v=ea5KeZ7Turg
the other shows pseudo-virus
http://www.youtube.com/watch?v=Yb_D__3m_0w
Mario C.
Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
mariocha
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby mariocha » Thu Oct 29, 2009 2:03 am
Wacov wrote:Got cloth smoothing working, and made it easier to change the scripting (everything's in the floor).
Ok I give up. Wacov, I just cannot see how this works. I have tried a few times. Refreshed my SkPh knowledge. Had fun with the new features.
But your cloths are a vast mystery to me.
The SkPh UI shows nothing.
Is it PC only ? Scripting only ?
Mario C.
mariocha
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Wacov » Thu Oct 29, 2009 12:17 pm
Basically, there's a physics object at the vertices of each panel of cloth. What you see in the simulation is Sketch Up geometry, which is created at the beginning of the sim, and modified in real-time; the main script is in the floor's scripted field, which creates a command used in the hidden physics objects.
Wacov
Postby JeremyGBertin » Mon Nov 30, 2009 7:20 pm
Hello Everyone, new member here.
Can anyone point me to a working example using the 'UnTouch' script functionality? I've played around with it, but can't quite seem to get it to work. I apologize if this has long since been covered somewhere, but I can't seem to find any examples. Thanks.
JeremyGBertin
Postby Davidfi1 » Mon Nov 30, 2009 7:31 pm
Did you mean OnTouch?
Davidfi1
Postby JeremyGBertin » Mon Nov 30, 2009 8:34 pm
No, I was not referring to the onTouch which is in the UI, but rather the opposite signal for when two objects stop touching.
Looking through the ruby code there seem to be events for onTouch, onTouching, and onUnTouch and I would like to know whether these are accessible for use. I am specifically looking for an example making use of an event which can fire code when two objects stop touching.
The effect I am trying to achieve it to set a variable when two objects come into contact, and clear the variable only when the objects move apart. Thanks!
JeremyGBertin
Postby Wacov » Mon Nov 30, 2009 9:40 pm
Basically, you use:
Code: Select all
ontouch{
   #your code here
   #code
   #code
   #more code
   #etc
In the scripted field. The code you put between the brackets will be executed, in the case of ontouch, upon every collision with another object. ontick{...}, onuntouch{...}, and ontouching{...} work in basically the same way, with ontick executed every frame, onuntouch whenever the object stops colliding, and ontouching every frame the object is colliding with another. With any of the the touch events, you can also access the object being collided with, the exact point3d of the collision, and the impact speed of the collision, using:
Code: Select all
   #code
You can then use them as variables in your event code.
Wacov
Postby JeremyGBertin » Mon Nov 30, 2009 11:20 pm
Thanks Wacov. Much appreciated.
JeremyGBertin
Postby hpnisse » Tue Dec 01, 2009 6:27 pm
Hello!
When I try the "ontouch" in script-field event it will not work:S
Ex. I have a "button" (box), and when I push that button it touch another box with the script (easy one, see below) the physics engine freeze and I need to restart the physics-simulator.
Here is the simple code I use:
Code: Select all
ontouch{
   setVar("var1",1)
Why does the physics-simulator freeze?
And will this script set the "var1" to "0" (zero) when I relase the button?
Thank´s for help.
/hpnisse
/hpnisse
Windows 7 U - Sketchup 8 - SketchyPhysics 3.2-Dec2 - from Sweden
hpnisse
Postby Wacov » Tue Dec 01, 2009 8:44 pm
The commands from RC1 no longer work in the scripted field, inluding get/setVar. The new variables are:
@var = 1
For a local (this group only) variable, retrieve it with:
@var
And:
@@var = 1
For a global (acessible from all groups) variable. Retrieve with:
@@var
Wacov
Postby JeremyGBertin » Wed Dec 02, 2009 4:37 am
Does anyone know of a way to allow for a Servo joint to rotate multiple revolutions?
It seems like the maximum workable range for the Servo joints are 360 Degrees (2*pi radians) symmetrical about the starting angle, and when exceeded the joint starts to endlessly spin around. I am looking to achieve multiple revolutions while still maintaining angular position control. Any ideas would be welcome. Thanks!
JeremyGBertin
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to SketchyPhysics
