SketchUcation Plugin Store
Groups, Components and Joints
Moderator: CPhillips
Postby jdc » Thu Sep 22, 2011 2:08 pm
I could really use some help regarding the relationship of groups to joints.
1. If I have a link ( a bar that will be connected to two others bars) with joints at each end Do I have to group them to the link all at once or can I group one joint to the link then group the other joint to the already grouped joint and link.
2. Do joints work with components the same way they work with groups.
3. Does it matter what order you joint connect a joint and group it?
Is there an advantage to doing one first?
4. I could really use a set of detailed rules about grouping joints. I have read as much as I can find but still do not have it all put together in my little brain.
Thanks for the help.
jdc
Re: Groups, Components and Joints
Postby DanYHKim » Wed Oct 19, 2011 3:49 am
I did a few experiments, because using joints is confusing.
So, I wanted to have a bar with a hinge at each end.
The bar would be joined to two other bars by the hinges (kind of like a semaphore arm).
I did not want the central bar to be static. I also wanted all three bars to be "solid" to each other. That is, they could not occupy the same space, but would block each other like solids.
1. Make the three bars
2. "Edit Group" the central bar
3. add hinges to the ends of the central bar
4. Close central bar group
5. Join the hinges each to one other bar
4. Secure the central bar to a static object, to hold it up.
Run simulation.
Result is that the two bars joined to the central one by the hinges will rotate as expected. The central bar acts like a solid with regard to its static holder.
Strangely, the central bar does not act like a solid WRT the joined bars. Instead, the two joined bars pass freely through the central bar.
--- Second experiment ---
1. Make three bars as before
2. Make two small squares.
3. Select one square and make it into a group.
4. repeat with the second square
5. "Edit group" one square
6. Add a hinge to this group, then close it.
7. Repeat with the other square.
8. Place the grouped hinges (hinge plus a square, all in a group) next to the two ends of the central bar and the bars making the two "arms"
9. Join one hinge to the central bar and one arm. Repeat with the other hinge.
10. Secure the central bar to a static object as a support
Run simulation
This works as I had hoped. The two arms rotate freely around their hinges, but do not pass through the central bar. Other objects physically interact with all three bars, acting as though they were "solid".
I will see if I can make a video of this, since my wordy description is probably not clear. Does this address some of your questions?
DanYHKim
Postby mptak » Wed Oct 19, 2011 1:18 pm
What an excellent post!
mptak
Re: Groups, Components and Joints - Now with Video!
Postby DanYHKim » Wed Oct 19, 2011 4:24 pm
I made a video of my experiments, and posted to YouTube.
http://www.youtube.com/watch?v=74ji-NXsdDI
For a simple articulated joint between two blocks, where the blocks must interact with each other and with other objects, and where the entire articulation is able to move about, the joint should be added to a third grouped object during an "edit group" action, making it into a moveable object itself, then joint-connected to the "arms" of the articulation.
Yeah, watch the video. My description confuses even me, and I wrote it!
DanYHKim
Postby tspco » Wed Oct 26, 2011 11:40 am
DanYHKim, I am glad someone did a new video recently. It seems that there aren't many using SP right now. Thanks for your post!.
tspco
Postby mitcorb » Wed Oct 26, 2011 12:12 pm
Could be that many of those who use SP are not so talkative.
Mr. Kim, I also appreciate your very eloquent and informative video.
User avatar
mitcorb
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Intermediate
Postby tspco » Wed Oct 26, 2011 12:57 pm
I realize that SP is not easy to use, but if you are persistent, you can make it work using whatever resources are available. As I learn stuff for basic operation of the plugin, I will post some videos also.
tspco
Postby x11joex11 » Sun Dec 11, 2011 4:55 am
I agree the video is very helpful, i've been having a very frustrating time understanding the physics engine and it was not for you to test all the different ways to do things and what errors could occur because of it.
x11joex11
Postby Don East » Sun Dec 11, 2011 5:04 pm
Excellent video tutorial.
Would like to see more.
Don
Don East
Postby superoudy » Mon Jan 09, 2012 4:17 pm
I am not so sure this is an oddity DanYHKim... I think this is an intended behavior which can be useful sometimes... You can always disable the default behavior and obtain the same result as shown in your video by checking the ConnectedCollide checkbox in the joint property window.
superoudy
Postby d.o. durant » Sun Feb 05, 2012 6:44 pm
DanYHKim wrote:I made a video of my experiments, and posted to YouTube.
Thank you for the clarification of a few things.
d.o. durant
Postby cholme » Thu May 17, 2012 4:01 am
I am pretty good at most programs and can figure out stuff pretty easily. I have had Sketchy Physics for quite a while now and rarely use it because I find it very unpredictable. Case and point, when I tried to do the exact same thing as in DanYHKim's video (i.e making the flat square and connecting the hinge to that etc.) it doesn't behave the same as in the video.
I am a furniture maker and frequently start SP but it is easier and faster for me to build a small, practical, prototype than to figure out how to get SP working with complex joints.
Any ideas for how to get a handle on this plug in? Manual? Video tutorials? Anything?
I LOVE the idea of it, and it seems like it is amazing but I just don't get it.
Thanks,
cholme
Postby Tunkmountainman » Fri Jun 08, 2012 7:25 am
Ok you sketchies....I have a Challenge for you...been working on this for a while and I give up. I want to make a model of a hydraulic cylinder...or an object with a hinge on one end and a shaft that moves in and out of the other end... that I can connect to other objects to move them in some fashion.
If I can learn how to use these joints then I can build my Physics test bench. I am always trying to design an arm or something and rather than doing it all on paper....I think Sketchyphysics would be Great.
Tunkmountainman
Postby DanYHKim » Fri Jun 08, 2012 6:14 pm
OK. Here is a machine I simulated in SketchUp/Sketchyphysics.
It is a mechanism to hold a set of infrared sensors above a cotton field. The IR reflectance of plants indicates some aspect of plant health, and so the sensors report plant reflectance to a small palmtop computer, which uses the data to apply fertilizer to the specific part of the field that is nutrient-poor.
Our machine is mounted on a Landini Mythos tractor. I slightly modified a similar-looking tractor that i downloaded from the 3D Warehouse, and then mounted the sensor mechanism. The elevation control on the model, as in the actual equipment, is controlled using a single piston that pushes on a pantograph, so the sensors remain level as they move up and down.
One surprise for me was that when the piston is extended from its lowest position, the swinging linker arm rotates forward and then suddenly rotates back. On later examination of video of the real machine, I found that the mechanism does the same thing in the field. This was rather satisfying to see.
Here is an embedded video of the machine and its model:
DanYHKim
Postby mitcorb » Sat Jun 09, 2012 2:49 pm
Congratulations!!! Excellent concept. Excellent video. Question- what is the function of the U bar suspended down below?
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
Postby scrollcrafters » Sat Jun 09, 2012 8:09 pm
I watched the video (well done, BTW) but still cannot get the desired interaction. All I'm trying to replicate is the hinge and box which I create as you did. I use the joint connector, first selecting the hinge and then the box. When I run the simulation,the box just drops downward. I simply cannot figure out what I'm doing wrong!
I'm using SketchyPhysics 3.2 and Sketchup 8, free version on a Windows XP system.
Mike
scrollcrafters
Postby Pilou » Sat Jun 09, 2012 9:46 pm
Have you pressed and hold CTRL when you click on the Join Connector and the group ?
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Level of SketchUp: Advanced
Postby scrollcrafters » Sun Jun 10, 2012 3:28 am
NO! I watched a video and did not pick up on that. I just tried it and get the proper simulation.
Thanks for the tip.
Mike
scrollcrafters
Postby DanYHKim » Mon Jun 11, 2012 2:54 am
mitcorb wrote:Question- what is the function of the U bar suspended down below?
The U-bar is used by the tractor driver to gauge the height of the plants he is running over. The IR sensor rack is raised so the bottom of that bar brushes over the tops of the plants. I think that determines the area that the sensors can "see".
DanYHKim
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Return to SketchyPhysics
Who is online
Users browsing this forum: No registered users and 2 guests
