Generation of Video Problem
General discussion about Animator for SketchUp
Postby berezen » Thu Apr 04, 2019 1:03 pm
Hello Fredo6!
Big Thank`s for your work and this amazing plugin
I have made made a mistake when setting up a plugin to generate video...I choose incorrect files when program asking me for "How to get FFMpeg"
(ScreenShot001)
after my mistake I have this:
(ScreenShot002) Looks correct, but it is not working. Error in the end of Generating
Now I understand how to make correct, I download right plugins (from here: http://ffmpeg.org/download.html)
BUT: I don`t know how to clear old incorrect plugins for Generate Video. How I can turn to situation in ScreenShot001?
(Deleting folders Fredo6 in plugins - didn`t work)
Really need Your Help!
berezen
Re: Generation of Video Problem
Postby fredo6 » Fri Apr 05, 2019 1:44 pm
berezen wrote:I don`t know how to clear old incorrect plugins for Generate Video. How I can turn to situation in ScreenShot001?
Just delete the old, invalid ffmpeg.exe and you should be back to the situation where Animator will ask you the location.
fredo6
PluginStore Author
PluginStore Author
Postby berezen » Tue Apr 09, 2019 7:04 am
Can`t find it
Can you tell exactly where to look? Which folder?
berezen
Postby fredo6 » Wed Apr 10, 2019 12:32 am
berezen wrote:Can`t find it
This is the place where you originally set the location of FFmpeg.exe
Open the Ruby Console and type
Traductor::FFmpeg.new.program_locate
I think I'll make a permanent command to change the setting of the location of FFmpeg. That will be easier when correcting mistakes.
fredo6
PluginStore Author
PluginStore Author
Postby alvin meza » Sat May 25, 2019 11:09 pm
como resolviste tengo el mismo problema descargo el archivo y copio lo que dice en la consola pero aun asi no me sale....
alvin meza
Postby Luigi62 » Thu Jun 13, 2019 1:28 pm
Hi Fredo,
I have the same problem as Berezen. While waiting for the update with a permanent command to change the setting of the location of FFmpeg, is it possible to have a detailed explanation in order to return to the original window asking "How to get FFMpeg" (by manually editing a file, for example)?
Luigi62
Postby fredo6 » Fri Jun 14, 2019 9:21 pm
Luigi62 wrote:While waiting for the update with a permanent command to change the setting of the location of FFmpeg, is it possible to have a detailed explanation in order to return to the original window asking "How to get FFMpeg" (by manually editing a file, for example)?
I have added a permament button in version 2.4d.
fredo6
PluginStore Author
PluginStore Author
Postby Luigi62 » Fri Jun 14, 2019 11:44 pm
Thanks a lot for your job !
Luigi62
Postby MKO » Wed Jul 17, 2019 1:24 pm
Pls a Fredo pop up is saying the animator 2.4d as expired. I tried updating through the link displayed but it won't pls what can I do?
MKO
Postby fredo6 » Wed Jul 17, 2019 5:10 pm
MKO wrote:Pls a Fredo pop up is saying the animator 2.4d as expired. I tried updating through the link displayed but it won't pls what can I do?
Unless you changed the clock on your PC, Animator v2.4d is valid till 14 Sep 19.
Fredo
fredo6
PluginStore Author
PluginStore Author
Return to Animator Beta
Users browsing this forum: Agus Bukhori and 1 guest
