Animator Follow Path
General discussion about Animator for SketchUp
Postby Mayoketchup » Mon Mar 04, 2019 3:02 pm
Hello
I'm trying to create an animation where an object follows a path. I'm using Fredo6's animator but I can't select a path after I selected the object. Am I doing something wrong ? I'm using SU 2018 pro.
Mayoketchup
Re: Animator Follow Path
Postby fredo6 » Tue Mar 05, 2019 4:16 pm
Mayoketchup wrote:HI'm using Fredo6's animator but I can't select a path after I selected the object. Am I doing something wrong ? I'm using SU 2018 pro.
Make sure the path are native Sketchup curves. Then they should be selectable from Animator Follow Path tool.
fredo6
PluginStore Author
PluginStore Author
Postby Mayoketchup » Wed Mar 06, 2019 4:31 pm
Hey Fredo
I noticed it doesn't work with native lines only with freehand and arcs.
I downloaded your bezier spline plugin and now it works perfect with these curves :thumb: .
Kind regards
Mayoketchup
Postby fredo6 » Wed Mar 06, 2019 6:11 pm
Mayoketchup wrote:I noticed it doesn't work with native lines only with freehand and arcs.
To create a Sketchup curve out of a sequence of edges, you need a Plugin, as this is (still) not provided by SketchUp in native, even in 2019!
The most popular plugin is TIG Weld. You have also some others: one by Eneroth3 and also Curvizard.
fredo6
PluginStore Author
PluginStore Author
Return to Animator Beta
