Remove button
General discussion about Animator for SketchUp
Remove button
Postby chri » Tue Jun 07, 2016 5:39 pm
when i use REMOVE BUTTON , movements are deleted however there are still in the list
is it possible to empty the list ?
Quand j'utilise le bouton Supprimer, les mouvements sont supprimés mais toujours dans la liste .
Est-il possible de vider la liste?
Chri
chri
Re: REMOVE BUTTON
Postby pilou » Tue Jun 07, 2016 6:15 pm
Edit with Nodepad++ the file "Name_of_object.animator" ? ;)
Speedy Galerie
Top SketchUcator
Re: REMOVE BUTTON
Postby fredo6 » Tue Jun 07, 2016 6:31 pm
chri wrote:Hi
Quand j'utiliser le bouton Supprimer, les mouvements sont supprimés mais toujours dans la liste .
Chri
Sequences are what you see in the dropdown. They are reusable pieces of animation.
Clip elements are what is in the clip timeline. They are instances of Sequences. You can have several instances in the same clip or in different clips.
This is similar to Sketchup Components, where you have a Definition (same as Sequences) and Component instances (as many as you like and with possibility to resize, move, rotate, etc...), which would corresponds to Clip Elements.
This is why removing a Clip Element does not remove the corresponding Sequence (which may have other instances somewhere else anyway).
If you want to remove a Sequence, go to the Maintenance Dialog Box.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: REMOVE BUTTON
Postby pilou » Tue Jun 07, 2016 6:50 pm
Very cool! :thumb:
Only thing: the window is resizable but the bottom line
Save Change Purge etc... stay at the bottom and don't follow the resize!
Not resize shown on this follow animation! :)
Speedy Galerie
Top SketchUcator
Re: REMOVE BUTTON
Postby chri » Tue Jun 07, 2016 7:06 pm
Fredo
OK
chri
Re: REMOVE BUTTON
Postby fredo6 » Tue Jun 07, 2016 8:16 pm
Be careful. PURGE ALL is really to remove everything!
Otherwise, just select the sequences you wish to delete. They won't be saved at the next Save.
Fredo
fredo6
PluginStore Author
PluginStore Author
Return to Animator Beta
Users browsing this forum: teh88888 and 1 guest
