[Tips] Animator Tips and Tricks
General discussion about Animator for SketchUp
Re: [Tips] Animator Tips and Tricks
Postby fredo6 » Mon Aug 19, 2019 12:29 pm
carloshmejia wrote:First of all thank you for your amazing plugins.
I am learning to use Animator. For some reason my original position changed and now it not correspond to my model. Are there a way to reset or change the original position of my clip?
Probably not...
There is a Positioner facility in Animator (4th icon), allowing you save and restore the position of objects. It is a good idea to save the position of objects before you start building animations.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby itaipeter » Thu Mar 26, 2020 4:13 pm
fredo6 wrote:The picto is explicit
Hello Fredo, thanks for the extension it's amazing and simple to use.
I'm having difficulty using the appearance function. for some reason, it doesn't work as it should.
I've messed with it in this project and suddenly as working the function refused to work with disappearing components.i've made a short video to explain.
thanks
itaipeter
Postby fredo6 » Thu Mar 26, 2020 4:20 pm
itaipeter wrote:The picto is explicit
Your video cannot be accessed. Maybe it is private.
fredo6
PluginStore Author
PluginStore Author
Postby itaipeter » Thu Mar 26, 2020 4:59 pm
it should work now. thank you
itaipeter
Postby fredo6 » Thu Mar 26, 2020 9:36 pm
I am not sure I understand the problems from the video.
Maybe posting the model would help so that I can have a look.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Guest » Sat Mar 28, 2020 2:03 pm
fredo6 wrote:I am not sure I understand the problems from the video.
Fredo
The problem is that the option of using the disappear option does not react to some Groups. and when it workes it doesn't recognize the XYZ boundaries for disappearing progressively.
here's a link to the file and to the animator file
https://drive.google.com/file/d/1lc1GrD ... sp=sharing
Animator:
https://drive.google.com/file/d/18GZUys ... sp=sharing
Guest
Postby itaipeter » Sat Mar 28, 2020 2:30 pm
update:
I've created a new file for trying the disappear apparition option and it worked perfectly.
somehow it's my file that is not corresponding with the plugin. I tried to delete all layers and purge the file but it didn't help.
here is another video to show that. (in this one the animator doesn't even react)
thanks,
itay
itaipeter
Previous
Return to Animator Beta
