[Tips] Animator Tips and Tricks
General discussion about Animator for SketchUp
Postby fredo6 » Wed May 11, 2016 10:30 pm
Waiting for a full user manual, this thread will cover some tips and tricks in Animator, which are not always obvious from the User Interface.
Save Strategy
Animator is a kind of application within Sketchup. Designing an animation is a long exercice, so you may stay long in Animator.
Animator provides a Save button. This saves the current animation data within the model (as attributes). A Save also creates a backup file, with the same name as the model and extension .animator. This is in case you exit abnormally.
By default, the model itself is not Saved in Sketchup however.
There is an AutoSave option available from the Default Parameters dialog box, to Save both Animator data and the Model.
Positioning the Sequencer and the Timeline in the viewport
The Sequencer is the rectangle containing the timeline and the tracks to position the sequences into clips.
Animator offers 2 types of configuration:
  • Left, Right, Top, Bottom for the position of the button palettes and sequencer in the viewport. These are the small green Arrows
  • Horizontal or Vertical Sequencer, which is the elongated rectangle close to 0 seconds
Scrolling in the Sequencer with MouseWheel
When scrolling is relevant, you can use the MouseWheel to scroll
  • by Tracks if the mouse is located in the scroll bar for Tracks
  • by Time whenever the mouse is located elsewhere within the Sequencer rectangle.
Clicks and Double-Clicks
  • whenever an animation is running a click in the viewport or timeline will pause it, with no other action
  • Button Launch Animation (green triangle):
    • a simple click will launch the animation from the current time in the timeline.
    • a double-click will launch the animation from the beginning, time = 0s
  • In the timeline:
    • a simple click will set the current time.
    • a double-click will launch the animation from the time clicked in the timeline, time = 0s
Undo - Redo in Animator
Because Animator is a plugin with long session (rather than just executing an action), forget about using the native Sketchup Undo / Redo button.
If you try to do it within Animator, the action will be neutralized (i.e. nothing will happen).
Instead, use the Undo / Rredo buttons which are managed by Animator for all modifications.
One small detail: Each Clip context has its own Undo / Redo stack. So if you open a clip, you can undo / redo actions only in the contexts of this opened clip. Going upward in the hierchy will activate the undo/redo stack of the parent clip.
At Exit of Animator
Animator restores the position of all objects and the view in the state they were at the launch of Animator.
Note: When running Animator, a click on the Play and Edit icons in the Animator toolbar will beep to prevent relaunching Animator. However, if Animator is in error and exit accidentally, you can unlock this feature by double-clicking on the icons.
Temporary exit to Sketchup
You can exit temporarily from Animator and go to Sketchup. There is a small "sketchup icon" in the button palette at the left.
This may be useful if you wish to take some measures in the context of the Animation at a given time, or do some modifications in objects contextually. Remember that if you exit Animator, you go back to the initial position of objects!.
Indeed, do not modify the position of objects already participating to an animation, or the hierarchy of groups / components for such objects.
In contrast, you can modify the flat geometry inside groups and components, as Animator only use Group and Component as a container.
You can use Sketchup native tools or any plugin.
When you have finished in Sketchup, Click on the button "back to Animator", or click on any icon in the Animator toolbar. You will go back to Animator in the exact same context as wehn you temporarily left.
So maybe useful, but be careful!
Disable and Remove elements in a Clip
  • You can disable / enable an element or several elements at once in a clip by clicking on the buttons of its property panel, or by dragging it (or them) in the timeline.
    A disabled element is just excluded from the Animation.
  • You can remove one or several elements by clicking on the button (bin) or dragging it outside of the sequencer rectangle. If you did it wrongly, use Undo to restore it.
Positioners
There are two small icons in the Animator toolbar for the Positioner Function
  • one marked with S, to Save the position of all objects and give it a name
  • one marked with R, to Restore a previously saved Positioner
This function is actually independent from Animator, and you can use it in other contexts.
In Animator, you can assign a positioner to a Film, so that it's initial object positions are those of the Positioner, not the one at launch of Animator. This is also a safe way to keep things well positioned, especially in case of errors or wrong actions. Or a way to capture intermediate steps of an animation for later usage.
Click on the name of the Film. A dialog box appears:
You can the either create a Positioner from the current position (button "Capture"), or assign an existing Positioner if already saved via the dropdown.
Maintenance
As a principle, Animator never 'deletes' objects. If you delete a clip or sequence from the timeline, it is simply marked as Deleted. This simply means that it won't be saved. However, you change freely your mind during the Animator session.
The management of all objects is done in a special section called Maintenance. This can be called by clicking on the dedicated button in the palette.
The dialog box appears.
You can review all existing objects with some useful information:
  • Where it used. Small icons show you if it participates in a clip or Film. Hover the icon with the mouse and you will get the names of these clips and films.
  • The number of instances of a sequence or clip. This is important to know, because it means every time you change it, you will potentially impact the animation in several places. As in Sketchup with Components, the benefit of re-usability means that you have to be constantly aware of what you did to control the scope of the modifications. As in Sketchup, Animator has a Make Unique function which can be used to cut inheritance.
You can delete a sequence or clip by clicking on the right-left red cross. again, this is just a mark for further deletion (i.e. not saving them).
fredo6
PluginStore Author
PluginStore Author
Re: [Tips] Animator Tips and Tricks
Postby solo » Thu May 19, 2016 7:56 pm
Fredo
I was watching the tutorials and I saw what you did to create spinning wheels, can you please explain the sequence of voodoo you used to create this?
http://www.solos-art.com
solo
Global Moderator
Postby ntxdave » Thu May 19, 2016 8:03 pm
solo wrote:Fredo
:D I had asked the same question.
In my car wash animation, I used a multiple of 360 degrees, adjust the duration of the sequence, and then used the repeat setting to control the wheels.
ntxdave
Postby fredo6 » Thu May 19, 2016 9:21 pm
solo wrote:Fredo
Say the diameter of the wheel is D (2.02 m), so the perimeter is Pi * D. This is the distance for a rotation of 360 degrees.
The offset of the forklift translation is 14 m. So you need 14 / (PI * D) rotation of 360 degree..
This gives the formula for the angle: 14 * 360 / 2.02 / 3.1416
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby solo » Thu May 19, 2016 9:25 pm
smarty pants. I'm too old to learn these tricks.
solo
Global Moderator
Postby wanniya » Wed Jan 11, 2017 7:33 am
Is there any way to work with section plane animation?
wanniya
Postby fredo6 » Sat May 19, 2018 10:10 pm
wanniya wrote:Is there any way to work with section plane animation?
This is coming in a new release tomorrow.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pilou » Sat May 19, 2018 11:02 pm
Useful for magician! :fro:
Speedy Galerie
Top SketchUcator
Postby fredo6 » Sun May 20, 2018 11:14 am
The picto is explicit
fredo6
PluginStore Author
PluginStore Author
Postby pilou » Tue Jun 05, 2018 3:15 pm
Can we add a Clip (or a movement) made in a previous session to the current session where an another is yet created ?
Say an object A (a Car) is on the screen and animated
A ball is an object B (a Ball animated) previously made in another session, can we add it to the car ?
Speedy Galerie
Top SketchUcator
Postby fredo6 » Wed Jun 06, 2018 7:36 am
pilou wrote:Can we add a Clip (or a movement) made in a previous session to the current session where an another is yet created ?
Any animation piece (i.e. sequence) created within a model can be integrated into a film, knowing that you can have many films within the same model. Think of a Sequence as a Component Definition in Sketchup. You can create instances of a sequence and insert them in the time line, change some parameters like duration, easing, ... (like you can scale a component instance in Sketchup). All sequences created in the model are accessible from the Insert buttons (for Movement, Cameras, Visual Effects, ....):
Note that you can also insert a full film
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby solo » Wed Aug 08, 2018 9:50 pm
I'm still using Thea 1.5, but I cannot get animator to work with Thea, it works perfect with straight SU output but nothing happens with Thea, at first it just rendered the 1st scene, now when I click 'render animation' it does nothing, what am I doing wrong?
solo
Global Moderator
Postby fredo6 » Thu Aug 09, 2018 7:43 am
solo wrote:I'm still using Thea 1.5, but I cannot get animator to work with Thea, it works perfect with straight SU output but nothing happens with Thea, at first it just rendered the 1st scene, now when I click 'render animation' it does nothing, what am I doing wrong?
Do you mean when you launch the rendering from Thea (not from Animator)?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby MANaboutTOOLS » Wed Oct 31, 2018 9:14 pm
I am using a Mac and cannot change the scale of the timeline to zoom in. When I mouse over the scroll bar it says "Use Mouse-wheel +ALT to change scale"
The equivalent on the Mac is the "option" key. When I push the option key and touch scroll the Mac magic mouse it zooms the model and not the timeline.
Kent
https://manabouttools.com
MANaboutTOOLS
Postby fredo6 » Wed Oct 31, 2018 11:09 pm
MANaboutTOOLS wrote:Hi,
Kent
I don't have a Mac to test.
Could you try with Command or Ctrl to see what happens.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby MANaboutTOOLS » Wed Oct 31, 2018 11:22 pm
I tried as many combinations as possible. All just zoom the model.
Kent
MANaboutTOOLS
Postby fredo6 » Wed Oct 31, 2018 11:54 pm
MANaboutTOOLS wrote:I tried as many combinations as possible. All just zoom the model.
Kent
Can you at least scroll the timeline (mousewheel, no modifier) and scroll the tracks (Ctrl + mousewheel), [assuming you have enough tracks) ?
fredo6
PluginStore Author
PluginStore Author
Postby MANaboutTOOLS » Thu Nov 01, 2018 1:54 am
I don't have enough tracks to test that. Will try tmrw.
MANaboutTOOLS
Postby MANaboutTOOLS » Thu Nov 01, 2018 7:16 pm
I changed a clip to make it longer so it brought up the scroll bars. I am unable to scroll the timeline with the mouse wheel. It always zooms the model window.
Kent
MANaboutTOOLS
Postby MANaboutTOOLS » Thu Nov 01, 2018 8:15 pm
Any keyboard shortcuts to zoom the timeline? Or any settings to key in a zoom value to get around this?
Kent
MANaboutTOOLS
Postby fredo6 » Thu Nov 01, 2018 10:32 pm
MANaboutTOOLS wrote:Any keyboard shortcuts to zoom the timeline? Or any settings to key in a zoom value to get around this?
Kent
Let's take things in order
1) without any modifier, putting the mouse cursor over the time, can you scroll the timeline?
2) with Option key pressed, and assuming you have enough tracks, can you scroll the tracks?
3) with Command key pressed, putting the mouse cursor over the time, what do you get?
fredo6
PluginStore Author
PluginStore Author
Postby MANaboutTOOLS » Thu Nov 01, 2018 11:04 pm
I can click-drag with the left button to scroll the time. I added enough tracks to test this.
1) No. Hovering the curser over the bar and gesturing with the magic mouse (scroll-wheel) zooms the model.
2) No. Zooms the model
3) With the mouse hovering over the scroll bar the time reads (for example) 25.5 s. If I press the command key the time then reads 25.50 s. And as above, mouse wheel gesture zooms model.
I hope this helps. Do you want a screen record?
Kent
MANaboutTOOLS
Postby MANaboutTOOLS » Thu Nov 01, 2018 11:26 pm
Here's a screenflow capture...
MANaboutTOOLS
Postby fredo6 » Fri Nov 02, 2018 9:25 am
Do you have a special mouse ?
fredo6
PluginStore Author
PluginStore Author
Postby MANaboutTOOLS » Fri Nov 02, 2018 1:30 pm
No, mouse came with the mac.
MANaboutTOOLS
Postby fredo6 » Fri Nov 02, 2018 6:14 pm
Could you open the Ruby Console when you run Animator and scroll with the mousewheel.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby MANaboutTOOLS » Sat Nov 03, 2018 1:27 am
Yes,
I have Ruby open. No difference.
Kent
MANaboutTOOLS
Postby juju » Sat Nov 03, 2018 9:36 am
MANaboutTOOLS wrote:Yes,
Kent
any messages in the ruby console when scrolling?
juju
Premium Member
Premium Member
Postby MANaboutTOOLS » Sat Nov 03, 2018 2:07 pm
No. Nothing
MANaboutTOOLS
Postby carloshmejia » Mon Aug 19, 2019 10:54 am
Fredo, first of all thank you for your amazing plugins.
Frequently the objects that I am animating lose its connection with the movements assign to them. Timeline seems OK, when you run the sequence it shows running except the objects don't move. What am I doing wrong?
carloshmejia
Next
Return to Animator Beta
Users browsing this forum: TonyAU and 2 guests
