Presenting FlexSlat - The second proud member of the Flex-Family!
Following FlexWindow, FlexSlat is also ultra light, simple and versatile – for quick generation of...
slat variations!
To purchase FlexSlat please visit:
http://frandzel3d.com/flexslat/
FlexSlat consists of the following components:
- frame profiles
- frame corners
- slats (2 separate instances for optimized usage – see ‘economode’ below)
- Sketchup 2015 and up
Usage:
- scale or type in measurements
- specify dimensions – frame and slats
- specify spacing and rotation in X,Y,Z +- random positioning and rotation
- set frame to 0 – frame hidden.
- inset guide – specify distance for easy placement
- frame guide – toggle guide visibility for when frame = 0.
- offsets – to improve positioning
- slat – length extension – extend slat edges until flush with frame.
- slat – reduction – reduce amount of slats from top and bottom.
Interact tool:
- on slat – redraw slat position/rotation
- on frame – redraw all
Notes:
Y/Z rotations:
- OFF – (‘economode’) – Y/Z rotations disabled. Component file size is kept to a minimum of 10 component instances no matter how many slats are generated.
- ON – Y/Z rotations enabled. Each new slat generated adds an additional component instance to the model. Highly Recommended to ‘purge unused’ when done generating.
- “no-dims” version included – for multiple component edits while maintaining original dimensions.
- “drag-n-drop” version included – drag from folder or components library directly into model with no need to explode.
I'd love to hear comments and suggestions for further development & improvement
A member of the Flex-family of Sketchup dynamic components.
Version History:
1.0
first version
