[BUG] SU mesh Validity Check error
General discussion on SUbD for SketchUp
Postby optimaforever » Tue May 09, 2017 9:12 pm
Hi all,
From time to time I get the infamous ***Problems were found that could not be fixed***
The entity at address ********** has an invalid id (****) destroyed (*)
during a random Validity Check when saving the skp.
I'm pretty sure it's related to SubD and QFT usage but can't solve the issue.
Anyone?
optimaforever
Premium Member
Premium Member
Re: [BUG] SU mesh Validity Check error
Postby thomthom » Wed May 10, 2017 10:26 am
What SU version?
What OS?
You mention both SUbD and QFT. Do you have some steps that reproduce? A model saved?
PluginStore Author
PluginStore Author
Postby optimaforever » Wed May 10, 2017 2:42 pm
If it doesn't ring a bell to you, it means I'm an isolate case?
The only way to solve the issue is to save, close skp and then reopen it...
But that doesn't explain me where the issue lies...
optimaforever
Premium Member
Premium Member
Postby thomthom » Wed May 10, 2017 2:45 pm
Not something I've seen or can recall hearing about before.
That error seems to indicate an issue with the entity ID of some entities - which is something only SU assigns.
I would need a way to reproduce in order to figure out what might be going on.
PluginStore Author
PluginStore Author
Postby optimaforever » Thu May 11, 2017 7:48 am
The thing is, if I save you a file, then when you'll reopen it, you probably will not see the error.
It only happens (eventually) when you're working and once it happens, you can't get rid of it until you close the file.
optimaforever
Premium Member
Premium Member
Postby thomthom » Thu May 11, 2017 3:39 pm
Have you noticed any patterns that lead up to this?
Also:
What SU version?
What OS?
PluginStore Author
PluginStore Author
Return to SUbD
