Version 2 is out!
General discussion on SUbD for SketchUp
Version 2 is out!
Postby thomthom » Mon Feb 20, 2017 2:43 pm
Now powered by OpenSubdiv
Check out full changelog here: http://evilsoftwareempire.com/subd/changelog/2.0
Oh - and by the way, there is currently a 50% discount of SUbD and Vertex Tools!
8
PluginStore Author
PluginStore Author
Re: Version 2 is out!
Postby Rich O Brien » Mon Feb 20, 2017 2:55 pm
Hooray!
Rich O Brien
Administrator
Postby optimaforever » Mon Feb 20, 2017 3:02 pm
Gr8!!!
Do we have to unistall v1 first or...?
optimaforever
Premium Member
Premium Member
Postby thomthom » Mon Feb 20, 2017 3:05 pm
optimaforever wrote:Gr8!!!
It should replace it. Should you find any problems - uninstall and install fresh. (And report back off course ;) )
PluginStore Author
PluginStore Author
Postby JQL » Mon Feb 20, 2017 4:23 pm
I wished I had time to play with this one. It's looking really great! Congratulations TT!
JQL
Premium Member
Premium Member
Postby optimaforever » Mon Feb 20, 2017 4:25 pm
Indeed, it replaced the v1 perfectly so far.
Thanks! :thumb: :thumb: :thumb:
optimaforever
Premium Member
Premium Member
Postby cotty » Mon Feb 20, 2017 5:21 pm
:D :thumb:
cotty
Top SketchUcator
Postby ithil » Mon Feb 20, 2017 6:59 pm
Wow! Great news!
I'm really happy. Many thanks for your work
ithil
PluginStore Author
PluginStore Author
Postby optimaforever » Mon Feb 20, 2017 9:23 pm
Is QFT your next release target?
optimaforever
Premium Member
Premium Member
Postby thomthom » Mon Feb 20, 2017 9:56 pm
It will probably be Vertex Tools 2.
PluginStore Author
PluginStore Author
Postby pilou » Mon Feb 20, 2017 11:02 pm
Damned: i must update my French SubD Mirror site! :enlight:
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Feb 21, 2017 12:15 am
Done! ;)
(publicity also) :)
Speedy Galerie
Top SketchUcator
Postby pilou » Wed Feb 22, 2017 9:32 pm
So...You are on Top Raw on the biggest French 3D Site! ;)
http://www.3dvf.com/actualite-19384-sub ... tchup.html
And in the news of CGTtalk! ;)
etc...
Speedy Galerie
Top SketchUcator
Postby thomthom » Wed Feb 22, 2017 10:21 pm
:D
PluginStore Author
PluginStore Author
Postby numerobis » Mon Feb 27, 2017 12:24 pm
Very nice update!
One question about the licensing... I just purchased v2 and installed it over v1. Without applying the v2 license key it appears to be licensed already. Is the v1 key also working for v2 or will it expire in 30 days? It only says "Licensed" without any other info.
And then i noticed a massive performance problem when the "SUbD Entity Info" window is opened. While toggeling subdivision "on" (again for an already subdivided object) without the window is almost instant it takes MUCH longer, maybe 10x-100x for the same action when the window is open. The first time i thought it had crashed.
Changing the UV interpolation setting is also incredibly slow.
Should i try a clean install? And if yes, is there more than the "TT_SUbD.rb" and the "TT_SUbD" folder that has to be removed?
SketchUp v2015, Win 7
numerobis
Postby alvis » Mon Feb 27, 2017 3:50 pm
finally! Thanks
alvis
Premium Member
Premium Member
Postby Oxer » Tue Feb 28, 2017 2:48 pm
I installed the v2.0 on OS X 10.11.6 & SU2017, the first run of the plugin all ok, but when I close the Entity Info window and I reopen it, the window shows --> "Nothing Selected" and I have a selected group.
Other times, if you have 2 entities with different SUbD applied and you change between them, the Entity Info window doesn't refresh the info. The Ruby Console is empty.
The Entity Info window doesn't show all buttons, I have to resize it manually because there isn't scrollbar.
http://www.oxervision.blogspot.com/
Oxer
Postby thomthom » Tue Feb 28, 2017 2:54 pm
Hm.. I will have to look into that. Might be that I'm not handling observers right for OSX multiple window interface.
Logged issue as #266
PluginStore Author
PluginStore Author
Postby Oxer » Tue Feb 28, 2017 3:09 pm
If you want that I test some feature especially, tell me it. Except the Entity Info, the rest of the icons work fine.
The Display Edges hides all edges in the model, not only the edges with SUbD applied, is this normal or is it a issue?
Oxer
Postby thomthom » Tue Feb 28, 2017 10:04 pm
Oxer wrote:The Display Edges hides all edges in the model, not only the edges with SUbD applied, is this normal or is it a issue?
That was the v1 feature. In v2 you have options to control this locally for the mesh.
PluginStore Author
PluginStore Author
Postby pilou » Thu Mar 02, 2017 2:43 am
Hello
Curious aspect of the icons! :o
Edit : Problem Solved! That was direct download first time! :ugeek:
I relaunch Su and now seems cool ! :fro:
Just a little thing : no Number of Version on title ?
Speedy Galerie
Top SketchUcator
Postby thomthom » Thu Mar 02, 2017 9:08 am
pilou wrote:Edit : Problem Solved! That was direct download first time! :ugeek:
I've never seen icon issues like that. What version of SU did you use? And what do you mean by "direct download"?
pilou wrote:Just a little thing : no Number of Version on title ?
No... how come?
PluginStore Author
PluginStore Author
Postby pilou » Thu Mar 02, 2017 10:05 am
Version is SU 2016 Make (as shown by the personnage of the young lady! ;)
Direct download = is Menu Preference / Extension/ Install Extension... without close SU and restart!
No... how come?
Can be useful for see in a glance what is the version used! ;)
(when you have a previous one installed and see if you have well installed the new)
Speedy Galerie
Top SketchUcator
Postby thomthom » Thu Mar 02, 2017 10:56 am
I'm not a fan of version numbers in menus and toolbars. The version number is listed in the Extension Manager (Or under Preferences > Extensions if you have pre-SU2017).
PluginStore Author
PluginStore Author
Postby cuttingedge » Thu Mar 02, 2017 1:21 pm
Thanks for this update thomthom. Im having more fun playing with quads. I was just wondering if you would consider including in future releases:
-Joint push pull (now that you have push pull)
-relax tool (may come inside vertex tool though)
-chamfer tool (may come inside QFT)
but hey, really thanks for making SU more fun and more functional.
cuttingedge
Postby thomthom » Thu Mar 02, 2017 1:34 pm
Yea, I have a relax prototype in the works. Not sure where it will manifest. VT is a likely candidate.
And I have many ideas for QFT.
JPP - would this be different from Fredo's JPP in any way?
(I really need to fix a number of issues with my current custom PP tool)
PluginStore Author
PluginStore Author
Postby Box » Thu Mar 02, 2017 1:58 pm
One thing I miss is the internal face removal, I found it very handy.
Am I missing it and it is still there somewhere?
Postby thomthom » Thu Mar 02, 2017 2:07 pm
Box wrote:One thing I miss is the internal face removal, I found it very handy.
Version 2 can handle internal faces - so it doesn't prompt you any more.
While working on localising I realised the code is still in there - just never used any more. I was wondering if it would be useful. So your comment is timely. Could expose it as a separate menu.
Though, I wonder if there is a strong enough use-case for a preference to force SUbD to ensure a mesh never have inner faces or forks...
PluginStore Author
PluginStore Author
Postby Box » Thu Mar 02, 2017 2:12 pm
You could add it as an option, I for one would use it all the time.
Postby thomthom » Thu Mar 02, 2017 2:43 pm
I'll make note of that. Thanks for the feedback.
PluginStore Author
PluginStore Author
Next
Return to SUbD
Users browsing this forum: HornOxx and 1 guest
