SubD examples and models
General discussion on SUbD for SketchUp
Re: SubD examples and models
Postby optimaforever » Thu Feb 04, 2016 12:27 pm
In the same order of idea, can you thomthom develop a quadchamfer4SU?
Ideally it would be a mix between the editability of SubD and the easiness of RoundCorner...
Roundcorner is good but it doesn't allow for editing. I have to keep a non-chamfered version in a temp layer if I need to edit it again. And SubD need manually offsetted lines to control the distance of chamfering. On complex models, it can quicky become a time-consuming burden, just to create chamfered edges, not to mention the file size and the memory footprint.
This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
What do you think?
optimaforever
Premium Member
Premium Member
Postby thomthom » Thu Feb 04, 2016 1:05 pm
Got some visuals to illustrate expected result?
PluginStore Author
PluginStore Author
Postby optimaforever » Thu Feb 04, 2016 2:15 pm
thomthom wrote:Got some visuals to illustrate expected result?
Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
3
optimaforever
Premium Member
Premium Member
Postby gilles » Thu Feb 04, 2016 2:45 pm
Streamliner, based on Norman E. Timbs 48 buick.
gilles
Top SketchUcator
Postby JQL » Thu Feb 04, 2016 3:39 pm
optimaforever wrote:This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
What do you think?
Actually I'm simply not using SubD, because it would be the most fun plugin I'd have, but it's not really useful for what I need right now. I would have yet another toy to have fun with and deviate my attention for what I do for a living... I must resist...
If you'd do it, it would be extremelly useful if you'd integrate it with SubD methodology and chamfer it only when subdividing, keeping UV's, allowing for creases worflow to be integrated too and, probably integrate it in the rendering workflow too.
I didn't know it yet but if SubD would be able to produce that, it would turn into the most useful toy an architect that deals with archviz needs apart from the renderers themselves.
Thanks for that feature request Optimaforever, I really hope Thomthom pulls that one off!
JQL
Premium Member
Premium Member
Postby pilou » Thu Feb 04, 2016 4:56 pm
@: Gilles where is the model ? ;)
Inspiration Vrooum, vrooum! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby gilles » Thu Feb 04, 2016 6:19 pm
pilou wrote:@: Gilles where is the model ? ;)
gilles
Top SketchUcator
Postby Stinkie » Thu Feb 04, 2016 10:07 pm
optimaforever wrote:Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
Oooh, it'd be great to have that in SU.
Stinkie
Postby optimaforever » Thu Feb 04, 2016 10:20 pm
JQL wrote:If you'd do it, it would be extremelly useful if you'd integrate it with SubD methodology and chamfer it only when subdividing, keeping UV's, allowing for creases worflow to be integrated too and, probably integrate it in the rendering workflow too.
Indeed, my next request would be that the quad chamfer only applies when rendering, a bit alla Skatter-way, with the "render only" option.
I don't know if it's in the pipeline but I guess that having the SUbD not visible when working and only visible during rendertime would be an equally useful feature. A kind of general SUbD toggle on/off in the SUbD preferences. The thing is, there is always an SUbD object on which I forget to apply the subdivision before pushing on the render button (lazy me), and having a "all subd on when rendering" toggle button would save my ass for sure :puke:
optimaforever
Premium Member
Premium Member
Postby pilou » Fri Feb 05, 2016 12:02 am
@ Gilles : Thx! ;)
Model by Gilles above!
The trick is colored first then SUbD ;)
Or there is another trick after the SUbD ?
Speedy Galerie
Top SketchUcator
Postby optimaforever » Fri Feb 05, 2016 1:21 am
very nice pilou ! :fro:
optimaforever
Premium Member
Premium Member
Postby HornOxx » Fri Feb 05, 2016 7:58 am
pilou wrote:... The trick is colored first ...?
typical French - you inspire a new fashion trend !! :-P
never trust a skinny cook
HornOxx
Postby thomthom » Fri Feb 05, 2016 11:10 am
optimaforever wrote:I don't know if it's in the pipeline but I guess that having the SUbD not visible when working and only visible during rendertime would be an equally useful feature. A kind of general SUbD toggle on/off in the SUbD preferences. The thing is, there is always an SUbD object on which I forget to apply the subdivision before pushing on the render button (lazy me), and having a "all subd on when rendering" toggle button would save my ass for sure :puke:
I'm in contact with some render engines in exploring way to allow them to render subdivided mesh independent from what is visible in the SU viewport. :)
6
PluginStore Author
PluginStore Author
Postby optimaforever » Fri Feb 05, 2016 12:15 pm
Thomthom, you're da man :D
optimaforever
Premium Member
Premium Member
Postby leminilab » Fri Feb 05, 2016 10:55 pm
Hi, Just uploaded a few objects modeled with basically Vertex Tools, and SubD:
https://3dwarehouse.sketchup.com/model. ... be495b50db
Thanks for the planet, man (if everybody could share their files in proxy mode (1,5 to 9,5Mb in my example), we'd save a lot of energy!
You well deserve the cookies you get! My hero! :)
- "Live every day as if it were your last and then some day you'll be right."
- "ThomThom rules!!!"
leminilab
Premium Member
Premium Member
Postby Stinkie » Sat Feb 06, 2016 12:31 pm
thomthom wrote:I'm in contact with some render engines in exploring way to allow them to render subdivided mesh independent from what is visible in the SU viewport. :)
Now that'd be quite something. :thumb:
Stinkie
Postby Box » Sun Feb 07, 2016 4:10 pm
I really do love the simplicity of modelling with the combination of QFT, VT and SubD.
4
Postby pilou » Sun Feb 07, 2016 7:07 pm
Vasarely revival! :fro:
Speedy Galerie
Top SketchUcator
Postby HornOxx » Sun Feb 07, 2016 8:24 pm
... a simple beverage can and a trial with texturing
5
HornOxx
Postby thomthom » Sun Feb 07, 2016 11:10 pm
HornOxx wrote:... a simple beverage can and a trial with texturing
Thanks for sharing that model. This will be useful to experiment with how OpenSubdiv handle UVs.
PluginStore Author
PluginStore Author
So how do i lace this shoe?
Postby cuttingedge » Sun Feb 07, 2016 11:21 pm
The hardest thing about having a shoe like this is lacing it especially when youre in a hurry....Im taking my time.. yet making this in 3d is proving to be more difficult than i ever suspected.
im happy anyways with how the shoe is taking shape.. :)
Tried 3 methods.. but i couldnt even show it...So how do i lace this shoe?... proxy attached in case..
how do ilace this shoe-off.skp
cuttingedge
Postby ely862me » Mon Feb 08, 2016 10:48 am
Why this won't subdivide ?
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
Postby thomthom » Mon Feb 08, 2016 10:56 am
ely862me wrote:Why this won't subdivide ?
It subdivided fine for me...
PluginStore Author
PluginStore Author
Postby Box » Mon Feb 08, 2016 10:57 am
Works for me.
Postby ely862me » Mon Feb 08, 2016 11:06 am
It doesn't work for me. I have sent the bug. I get one every time I try it.
ely862me
Top SketchUcator
Postby micione » Mon Feb 08, 2016 11:32 am
Elisei ,
check your other plugins.
it is a conflict.
micione
Postby Rich O Brien » Mon Feb 08, 2016 11:36 am
works for me too
Rich O Brien
Administrator
Postby ely862me » Mon Feb 08, 2016 11:44 am
I thought this was happening only with this model, but it seems it happens with all. I don't remember doing any changes later. This is a bit strange. Maybe Thomas has some hints from the error I sent his way.
Edit
Thomas, have you released any updates recently ?
When I went to the Welcome to SubD panel it said a new version is available. Then I went to the SCF pluginstore and installed SubD. Now it seems to work.
ely862me
Top SketchUcator
Postby thomthom » Mon Feb 08, 2016 1:14 pm
ely862me wrote:I thought this was happening only with this model, but it seems it happens with all. I don't remember doing any changes later. This is a bit strange. Maybe Thomas has some hints from the error I sent his way.
Edit
When I went to Welcomne to SubD panel it said a new version is available. Then I went to SCF pluginstore and installed SubD. Now it seems to work.
You where running an expired beta build. Guess you didn't update after the release.
PluginStore Author
PluginStore Author
Postby ely862me » Mon Feb 08, 2016 1:37 pm
Strange as it worked until today !
I believe I didn't update after the release.
Thanks, back and runnin' fine !
ely862me
Top SketchUcator
PreviousNext
Return to SUbD
