Reversed Selection Behavior
General discussion on SUbD for SketchUp
Postby plot-paris » Fri Apr 21, 2017 10:55 am
Hi Thomthom,
when modelling a sofa with your superb plugin I came across a peculiar behavior, that seems to occur with any geometry generated with SUbD, whether it is a live SUbD object or a plain mesh generated from it...
Surely you are familiar with the excellent trick of SketchUp, where the direction in which you draw a selection frame influences what is being selected.
  • When you draw from left to right, only geometry completely enclosed by the selection frame is being highlighted
  • When you draw from right to left, all geometry touched by the selection frame is being highlighted.
Now, with a SUbD mesh, selectin in such a manner does work. If however you press SHIFT / CTRL or both to add or subtract from a selection, this behavior is reversed (or behaves in another, unpredictable manner). Can you reproduce this?
To make things easier, I have attached a file with a SUbD mesh on the left and an ordinary object on the right. Here you can easily see the difference when selecting using the modifier keys.
This is not a big issue, of course. But interesting nontheless ;-)
User avatar
plot-paris
Re: Reversed Selection Behavior
Postby thomthom » Fri Apr 21, 2017 11:54 am
When you have a subdivided mesh and you perform selections SUbD will try to expand the selection of the sub-entities to match the original control-entities.
Unfortunately the API was lacking some feature to implement this to match SU's original behaviour. However, recently I think this has become possible. I have an issue logged to improve the box-selections.
User avatar
PluginStore Author
PluginStore Author
Postby plot-paris » Fri Apr 21, 2017 2:30 pm
Ah, I see. That does make sense.
However, this behavior seems to stay with the geometry, even if you convert it to a plain mesh and explode the group. Could you find a way to undo this on conversion?
User avatar
plot-paris
Postby thomthom » Fri Apr 21, 2017 8:45 pm
Hmm... that is strange, if you convert to plain mesh SUbD should not be interfering...
Can you show a video/gif of what you observe? Maybe we are talking about different things?
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SUbD
Who is online
Users browsing this forum: No registered users and 3 guests
Visit our sponsors:
