Deleting Skatter trees...
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby pointsixoneeight » Sun Aug 11, 2019 7:19 pm
How do I fully remove the scatter information from a model? I have deleted all that I can find and still they appear in my VRAY Render....
pointsixoneeight
Premium Member
Premium Member
Re: Deleting Skatter trees...
Postby jiminy-billy-bob » Mon Aug 12, 2019 8:56 am
- Download and install v1.4.8 : https://getskatter.com/download/
- Go to Extensions > Skatter > Purge all Skatter data
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Mon Aug 12, 2019 9:53 am
Is there a way of purging just some Skatter data?
Like Purge selected's Skatter data?
User avatar
Pixero
Postby jiminy-billy-bob » Mon Aug 12, 2019 12:13 pm
The Purge is intended to be used when some data has been corrupted for some reason, and Skatter is not able to process it.
What would you like to be able to select to be purged?
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Mon Aug 12, 2019 12:39 pm
If you have several skatters in the SU scene you might want to only purge one of them if that one is problematic.
User avatar
Pixero
Postby jiminy-billy-bob » Mon Aug 12, 2019 5:52 pm
I understand.
But this function is here as a last resort. If Skatter is able to identify a single setup, you should be able to remove it from the Render List. If not, it will not be able to target it.
You can always send problematic files to skatter@lindale.io and we'll do our best to clean them.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby dascorp » Thu Sep 03, 2020 10:37 pm
I have an issue where Skatter objects are automatically purged erased or deleted with no reason.
the error says:
Skatter error (Skatter 1): The Component definition 'skatter_medium_grass_01_large_proxy' has been erased from the model.
Both Vray and Skatter latest releases but SketchUp 2019
It worked before
dascorp
Postby jiminy-billy-bob » Fri Sep 04, 2020 9:00 am
This is caused by V-Ray 4.20.03. More info here: https://forums.lindale.io/t/major-issue ... 20-03/2593
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Skatter
Who is online
Visit our sponsors:
