Help please, skatter didnt star “IndexError”
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby niel91 » Thu Jun 27, 2019 2:26 pm
SketchUp version : 2019
Skatter version (Skatter dialog > Options > About) : 1.4.7
OS : w10
Description of the issue :
If i started a new project, skatter will work perfectly, but when i opened an oldest file (like 2017/2018 with the same plugin) it gives me a ruby error in the begining and not working
Are you able to reproduce the issue every time? (If yes, how?) :
Error in Ruby Console? (Window > Ruby Console) :
Error: #<IndexError: index 268435456 too big>
C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/generate_points.rb:201:in cpp_generate_uniform_points' C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/generate_points.rb:201:inblock in generate_points’
C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/generate_points.rb:143:in each' C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/generate_points.rb:143:ingenerate_points’
C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/methods.rb:889:in refresh' C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/methods.rb:730:inrefresh_from_attributes’
C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/methods.rb:606:in block (2 levels) in startup' C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/methods.rb:603:ineach’
C:/ProgramData/SketchUp/SketchUp 2019/SketchUp/Plugins/jbb_skatter/rb/methods.rb:603:in block in startup' c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:inis_online’
c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in initialize' c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:innew’
c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in <main>' c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:ineval’
c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in require' c:/users/utilizador/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in’
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:inrequire’
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/utilizador/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_dynamiccomponents.rb:47:inregister_extension’
niel91
Return to Skatter
cron
