Need to Have Vegetation Controlled by Layer
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby Bob James » Tue Dec 27, 2016 9:33 am
I have a large model which is used for several scenes. There are several areas that have unique vegetation scattered on them.
The problem is that in one scene the first set of areas and associated vegetation are used. In the next scene, the same location has a different set of areas and associated vegetation. But the vegetation from the first set is still there.
I have no way to turn off the vegetation from the first set of areas when I'm using the second set of areas and their associated vegetation.
Bob James
Premium Member
Premium Member
Re: Need to Have Vegetation Controlled by Layer
Postby jiminy-billy-bob » Tue Dec 27, 2016 10:29 am
You should create two separate setups that you can turn on and off in the Render List.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Bob James » Tue Dec 27, 2016 1:00 pm
Got it. Thank you.
Bob James
Premium Member
Premium Member
Postby jiminy-billy-bob » Tue Dec 27, 2016 1:20 pm
Using the checkbox next to each setup in the Render List.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Bob James » Tue Dec 27, 2016 1:40 pm
Gave it a try: works fine. However, this only works in thea4su, it won't have any effect once the model is in Studio.
I do my final renders in Studio in order to set the render resolution (I do most of my production runs at 5400x3600 to print them at 12" x 8" at 300 dpi)
Bob James
Premium Member
Premium Member
Postby Bob James » Tue Dec 27, 2016 1:59 pm
After re-reading the manual I found this:
Tip: When rendering interactively a screen resolution instead of
camera resolution is being used. Disable ‘Interactive’ option to render
at full size.
I've been rendering using Presto AO so that's why I could only get screen resolution. I can try other than interactive like TR1. The problem with that is TR1 is very slow compared to Presto AO.
Bob James
Premium Member
Premium Member
Postby jiminy-billy-bob » Tue Dec 27, 2016 2:53 pm
With Presto selected, you need to untick the "Interactive" checkbox.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Bob James » Tue Dec 27, 2016 10:18 pm
:oops: Duh
Bob James
Premium Member
Premium Member
Return to Skatter
cron
