[RELEASE] Skatter v1.3.0
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby jiminy-billy-bob » Wed Dec 21, 2016 3:32 pm
1.3.0
In the new version 1.3.0 of Skatter, you can now create complex green walls, or anything else scattered on vertical surfaces.
Here is a complete tutorial one how to do it : http://skatter.helpscoutdocs.com/articl ... green-wall
The high quality plant models used in this example are from Lotfi Bernoussi.
You can download them here : https://gumroad.com/l/tOyB
Changelog:
  • Added custom projection axis
  • Added "Swap object's Z and Y axis" when Pointing Direction is 100% to Normal
  • Fixed an important crash/freeze when opening SketchUp when Skatter doesn't find surface group/component
  • Fixed object orientation when using Pointing Direction
  • Fixed grass color and saturation
  • Fixed trees and bushes Vray ID mixup
  • Fixed Size/Distance boundary check when the surface is a solid (no boundaries)
Download : http://download.getskatter.com/
3
jiminy-billy-bob
PluginStore Author
PluginStore Author
Re: [RELEASE] Skatter v1.3.0
Postby Rich O Brien » Wed Dec 21, 2016 3:39 pm
Great update :thumb:
Putting in a feature request for Children...
https://www.blender.org/manual/physics/ ... ldren.html
...no rush. Monday? ;)
Rich O Brien
Administrator
Postby boofredlay » Wed Dec 21, 2016 3:41 pm
Cheers for the update :!:
boofredlay
Global Moderator
Postby andybot » Wed Dec 21, 2016 4:00 pm
wow, that looks really great! :thumb:
Thanks for linking the plant library, looks like a worthwhile purchase.
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby baz » Thu Dec 22, 2016 1:39 am
Looks great. But I am getting an error msg...' Please restart Sketchup to complete the Skatter update'.
Which of course I have done several times...
... If I click ok, scatter seems to open normally, but following your 'Wall' tutorial, unable to 'Pick axis'. I get msg 'You have already picked this surface' and blue axis arrow is pointing down.
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby Pixero » Thu Dec 22, 2016 10:54 am
Great update...and image. :thumb:
I'm wondering how that would look from another perspective though?
Maybe closer to the wall and with a more dramatic perspective?
Pixero
Postby baz » Thu Dec 22, 2016 12:13 pm
Pixero wrote:Great update...and image. :thumb:
yeah, that would be good if i could get it to work...
baz
Postby jiminy-billy-bob » Thu Dec 22, 2016 12:20 pm
baz wrote:Looks great. But I am getting an error msg...' Please restart Sketchup to complete the Skatter update'.
Which of course I have done several times....
Try installing as admin.
Right-click the installer, then "Run as Administrator".
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby jiminy-billy-bob » Thu Dec 22, 2016 12:21 pm
You can try it yourself, I gave the scene to Lotfi so it is included in his collection.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby baz » Thu Dec 22, 2016 12:35 pm
I did read the install instructions, so I did 'run as admin'
So should I uninstall (somehow) and try again?
baz
Postby jiminy-billy-bob » Thu Dec 22, 2016 12:38 pm
Yes, I'd try a full uninstall an reinstall.
I guess it's already the case, but just to be sure : SketchUp is not running when you install, right?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby baz » Thu Dec 22, 2016 12:55 pm
jiminy-billy-bob wrote:Yes, I'd try a full uninstall an reinstall.
yes, all programs except firefox closed during install.
Ok did a reinstall and 'pick axis' seems to be working, but now won't regenerate.
Happy Xmas, I'm having a few days off. See you in the new year. xx
baz
Postby jiminy-billy-bob » Thu Dec 22, 2016 12:59 pm
baz wrote:but now won't regenerate.
What happens exactly? Anything in the ruby console?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby tomot » Thu Dec 22, 2016 10:12 pm
How does Skatter work with Lumion rendering?
I do some free lance design work with a firm that uses Lumion.
I'm wondering if I should recommend they invest in Skatter.
cheers!
tomot
PluginStore Author
PluginStore Author
Postby jiminy-billy-bob » Fri Dec 23, 2016 11:39 am
Skatter and Lumion can't be tightly integrated, as Lumion doesn't run inside Sketchup, but some people use both together anyway : http://danieltal.com/skatter-extension-part-2/
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby baz » Mon Dec 26, 2016 11:42 am
I am able to set the Axis and although the regenerate button seems to accept the click, the model does not update.
And with 71 simple cubes, unticking 'render only' shows the proxies only.
A test render in Twilight shows only the group.
Edited. Deleted the Ruby code.
baz
Postby jiminy-billy-bob » Mon Dec 26, 2016 11:45 am
Can you send me your file to support@getskatter.com ?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Return to Skatter
Users browsing this forum: lucasconiglio and 3 guests
