[Q] Save Skatter Results
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby Bob James » Sat Sep 03, 2016 9:06 am
I've taken a subset of my master model's typography and Skattered some trees on it. I tried "selecting all", copying and pasting, but lost the trees.
I've also tried exporting the result as a Thea Scene, but that also loses the skattered trees.
Is there any way to save the skattered result so I can re-use it in my master drawing?
Update
I also tried saving into the Library custom paths, but could find nothing in the folder that it was "saved" to that looked like it had anything to do with Skatter
User avatar
Bob James
Premium Member
Premium Member
Re: [Q] Save Skatter Results
Postby jiminy-billy-bob » Sat Sep 03, 2016 4:10 pm
You have two options:
1. Create a small surface. Edit your Skatter setup, remove the hosts and pick the newly created surface. The generate in normal mode (not render only). This will create a group in your model that you can then copy/paste along with your original surface. Once pasted in the new model, right click your Skatter group and click "Edit Skatter Group". Skatter will complain that it can't find the surface anymore, just pick it again, and now you can regenerate with Render Only.
2. Save your setup as a preset in the Library. Copy/paste your surface in your new model, then load your preset from the library and pick your surface.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Bob James » Sat Sep 03, 2016 11:28 pm
jiminy-billy-bob wrote:2. Save your setup as a preset in the Library. Copy/paste your surface in your new model, then load your preset from the library and pick your surface.
What is the library file called? I don't see it in the folder in which it was supposedly saved.
User avatar
Bob James
Premium Member
Premium Member
Postby jiminy-billy-bob » Sun Sep 04, 2016 11:21 am
When you save a preset, Skatter creates a .sklib file along .skp files (the scattered objects saved as components).
Example with two scattered objects :
- preset.sklib
- preset1.skp
- preset2.skp
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Bob James » Sun Sep 04, 2016 12:00 pm
Then why are there no "preset" files in the folder shown in the "Library Custom Path"?
User avatar
Bob James
Premium Member
Premium Member
Postby jiminy-billy-bob » Sun Sep 04, 2016 12:18 pm
"preset" was just for the example, the files will have the name you give it when you save it.
Are there any .sklib file in there?
Don't you see your preset in Skatter Library browser in Sketchup?
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Skatter
Who is online
Visit our sponsors:
