Extension Store v3.0
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Re: Extension Store v3.0
Postby facer » Tue Apr 18, 2017 1:57 am
REQUEST:
It would be helpful to SEE the LOADED sets assigned.
Sets often reflect a set workflow for stages as Sketch Design, Design Development etc.
During the use of SketchUp, extensions/plugins are often added or removed to assist
specific current activities or issues.
When returning to the project it would be helpful to RESET the
WORKING SET - assigned to a given workflow. This would help others using
the same SketchUp file.
Thank you again for all the Teams work on the Extension Store.
User avatar
facer
Premium Member
Premium Member
Postby filibis » Thu May 04, 2017 9:41 am
I mostly downloaded my plugins & extensions manually and realized benefits of Extension Store lately. So is there any way to make it 'recognize' my plugins or should i download them all one by one via Extension Store :ecstatic: ?
Also can Extension Store detect plugins in my path (plugin folder) whether they're available in Sketchucation or not? (Thus, i can distinguish -that i gathered from other sources- easily and zip them)
This question is also asked at the end of this Bundles tutorial and didn't receive any reply.
Besides i have no idea how Plugin-sets work. I created a set but don't know how to add/remove plugins to that set (and i don't know which plugins are applied to my set). Is there any info on that?
User avatar
filibis
Postby Rich O Brien » Thu May 04, 2017 9:47 am
We can't detect anything outside so you need to use it to create a history.
There's a new version of the store coming where we want to offer more in terms of allowing users to add external extensions links into the store. So if there's a scenario where someone finds something they think the community would like to know about you could submit a listing.
You will also be able to create Collections that you could share with others that allows them to install a set of tools you curate as needed for a certain task.
We also want some type of 'Ask' scenario. If you wanted to know how to do A+B then members can reply with their solution.
3
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby powermta » Thu Aug 24, 2017 4:47 pm
Seems great, i hope it still works
powermta
Postby Bob James » Sat Aug 26, 2017 9:43 am
May 04, 2017
"There's a new version of the store coming "
August 26, 2017
:?: :!: :fro:
User avatar
Bob James
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Skatter
Who is online
Users browsing this forum: MOR55 and 1 guest
Visit our sponsors:
