[RELEASE] Beta 0.1.0
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby jiminy-billy-bob » Sun Aug 09, 2015 5:38 pm
Beta 0.1.0
Don't forget to restart Sketchup after install.
Changelog:
  • Added Paint Areas
  • Added distribution along curves
This is the first version of the Beta cycle, as I won't be adding any more feature before the v1 public release. From now on, I will focus on bug fixing, UI, OSX version, and other stuff (licensing, website, etc)
You can continue to request feature, they will be added to the todo list for future versions. But now I mostly need you guys to track down bugs and crashes. ;) Thanks
If needed, same serial as before : 6sblp-7GdCN-Z1Y3X-E0O4a
jiminy-billy-bob
PluginStore Author
PluginStore Author
Re: [RELEASE] Beta 0.1.0
Postby JQL » Sun Aug 09, 2015 6:56 pm
Excellent news Jiminy,
I'm a bit sad for not having skatter on vertical faces for the public release... Please don't forget about that one!
Nige, can you find the differences: :lol:
NigeC wrote:I know its something you shouldn't do but I'm good at thinking idiot lol
NigeC wrote:It’s only impossible if you stop and think about it!
JQL
Premium Member
Premium Member
Postby jiminy-billy-bob » Sun Aug 09, 2015 7:12 pm
JQL wrote:I'm a bit sad for not having skatter on vertical faces for the public release... Please don't forget about that one!
I didn't forget! But it's quite tricky, it's going to require a lot of work. For now, I prefer focusing on getting a first version out.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby jiminy-billy-bob » Sun Aug 09, 2015 10:20 pm
Nige, I moved the conversation in a new topic : viewtopic.php?p=574610#p574610
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby valerostudio » Wed Aug 12, 2015 5:15 pm
Skatter has reached God status!
valerostudio
Postby Pixero » Thu Aug 13, 2015 10:29 am
I'm having a problem when using two skatters. One for the main area and one for the edge.
Sometimes just one or none of them render and I have to edit them and regenerate to make them both visible.
Is it a "feature" or a bug?
Could it be a memory issue?
I'm on the edge with my laptops 2GB gfx card and sometimes exceed the available memory limit.
Pixero
Postby jiminy-billy-bob » Thu Aug 13, 2015 10:31 am
This might be a bug.
Can you find any pattern for when one or the other is not rendered?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Thu Aug 13, 2015 10:33 am
I've edited the original post.
Pixero
Postby jiminy-billy-bob » Thu Aug 13, 2015 10:38 am
Hmm, yeah it could be a memory issue. I'm not sure.
2GB is the GPU memory?
Does it happen when rendering with the CPU only?
When it happens, does the Thea Console displays any error or warning?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Thu Aug 13, 2015 10:47 am
I'll try to make some tests tonight.
Pixero
Postby Pixero » Fri Aug 14, 2015 12:43 pm
This is what I get in the console when opening the Skatter scene:
Code: Select all
---- Skatter ----
Error: #<NoMethodError: undefined method `[]' for nil:NilClass>
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:606:in `block in refresh'
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:601:in `each_pair'
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:601:in `refresh'
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:590:in `refresh_from_attributes'
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:462:in `block (2 levels) in startup'
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:460:in `each'
C:/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:460:in `block in startup'
SketchUp:1:in `call'
Pixero
Postby jiminy-billy-bob » Fri Aug 14, 2015 12:47 pm
Thanks!
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Fri Aug 14, 2015 12:54 pm
I'll be coming to London by the way so I guess I'll see you there.
I won't recognize you by your avatar though I guess... ;)
Pixero
Postby jiminy-billy-bob » Fri Aug 14, 2015 12:57 pm
Haha indeed. I'll probably be wearing a Skatter Tshirt, and I guess we'll all have a named badge.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Return to Skatter
