Don't forget to restart Sketchup after install.
Changelog:
- Added save new library item
- Added auto-generate when picking surface after loading library item
In the options, you can check/add/remove custom paths where the library looks for items. When you save a new item, its path is automatically added.
I was planning to add the paint areas for this release, but even though I have made good progress, it's not finished. So I release only this, as I'm leaving tonight for 3 weeks of vacations.
If needed, same serial as before : 6sblp-7GdCN-Z1Y3X-E0O4a
