insane memory usage
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
insane memory usage
Postby NigeC » Sun May 17, 2015 4:30 pm
I'm memory deficiently challenged both physically and hardware and I am quite alarmed by the amount of memory required to select a large mildly sub divided plane and I'm running out of memory just trying to add the surface.. I have 8gb Ram when I killed the process it was at 5gb and climbing
SU2015
latest internal thea4su
Win7 64 8GBram i7 3770k unclocked
“It’s only impossible if you stop and think about it!”
NigeC
Re: insane memory usage
Postby jiminy-billy-bob » Sun May 17, 2015 6:24 pm
I'm not having any issue with your file.
What did you do exactly, and when did the memory start rocketing?
Is Sketchup responsive while the memory is going up?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby NigeC » Sun May 17, 2015 6:51 pm
I just loaded the scene, tried to select the surface which changes blue then SU just totally hangs as I click on it, its also difficult to get the task manager to open
SU only has Skatter, Maxwell (shhhhh) The4SU, 1001 Tools, Keyframe Animation, Sufoyou
I'll try disabling the plugins and see if any effect it
NigeC
Postby NigeC » Sun May 17, 2015 7:04 pm
When I start Sketchup the Skatter panel always shows regardless of whether I closed it the last time I used SU, the memory issue only happens if I use the panel that appears at start up, if I close it and reopen scatter it works instantly
NigeC
Postby jiminy-billy-bob » Sun May 17, 2015 7:06 pm
Interesting. Thanks for you feedback
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby NigeC » Sun May 17, 2015 7:17 pm
this is what happens in ruby console.. the memory was at 99% at one point :o
When after closing/ reopening the panel the SU scene is only 350meg and the console has
---- Skatter ----
Processing surface 1kqp7n7wX6se_MccTb$HSh
Sent surface to C++ : 0.005 s
Generate points : 0.006 s
Number of generated points : 10000
Project points : 0.029002 s
Number of projected points : 10000
Seed and def points : 0.006001 s
Area points : 0.008 s
Number of areaed points : 10000
Points to lines : 0.024001 s
Total number of points : 10001
View redraw : 0.044003 s
Total : 0.142008 s
------ End ------
NigeC
Postby tomasz » Fri May 29, 2015 8:39 am
NigeC wrote:Maxwell (shhhhh)
What?! ;)
tomasz
SU2TH & SU2KT Developer
Postby JQL » Fri May 29, 2015 9:47 am
What?! ;)
LOL! Treason!!!
Espionage?
Double agent?!
:lol:
JQL
Premium Member
Premium Member
Return to Skatter
cron
