[BUG?][Q?] I can't generate any render with Thea
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby JQL » Wed Dec 17, 2014 1:19 pm
I still couldn't render anything with skatter. Thea here.
I must be doing something wrong but don't know what.
Here is the pic:
- On the right cube there's a skatter with actual geometry (a 2d person) being nicely generated after ckicking on Generate.
- On the middle there's a surface with a grass patch wich is a Thea Proxy, not being rendered.(The proxy is on the middle of the two cubes, scaled up for you to see it). Notice my skatter render list is empty.
- Also on the file, on the left, there's a volume I use for template because it is subdivided for displacement and that volume can't act as a surface, because SU bugsplats.
Here is the file:
Thea not rendering.skp
Win7 64bit
SU2015 64bit
JQL
Premium Member
Premium Member
Re: [BUG?][Q?] I can't generate any render with Thea
Postby tomasz » Wed Dec 17, 2014 1:47 pm
There was last minute quick "improvement" that ruined the export.
I will post an update in Thea forum.
Btw. Only external models can be "Scattered" for the time being.
tomasz
SU2TH & SU2KT Developer
Postby JQL » Wed Dec 17, 2014 2:24 pm
tomasz wrote:Btw. Only external models can be "Scattered" for the time being.
Hi Tomasz,
That's what I thought at first when I wast trying to render the humanoid. Then, when the same stuff happened with the proxy I was puzzled.
Thanks!
JQL
Premium Member
Premium Member
Postby JQL » Fri Dec 19, 2014 1:16 am
Well here it is, my first plantation of Granobs. It's something that grows well on doors...
Thanks guys!
JQL
Premium Member
Premium Member
Return to Skatter
