[BUG] V-Ray Stops Rendering
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby valerostudio » Wed Dec 03, 2014 8:57 pm
I tested the latest Skatter3 using the VR proxy option and it rendered great once, then if I click R again, I see the next saying VRay Render starting, then nothing.
valerostudio
Re: [BUG] V-Ray Stops Rendering
Postby jiminy-billy-bob » Wed Dec 03, 2014 9:22 pm
Anything in the ruby console? Or in Vray's python console?
Is Sketchup responsive?
What version of Vray are you using?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby andybot » Wed Dec 03, 2014 10:02 pm
Just loaded skatter 0.3. Here's my vray error from the Ruby console:
su2015 x64, windows 7, vfs sp3 (2.00.25244)
==== V-Ray for SketchUp =====
Done processing compdefs - Elapsed time: 0.160
Scene processed in 0.170 seconds
undefined method `keys' for #<Array:0x000000215b15c8> + ["C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1784:in `block (3 levels) in write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1783:in `each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1783:in `block (2 levels) in write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1782:in `each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1782:in `block in write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1781:in `each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1781:in `write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1980:in `start_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PCallbacks.rb:538:in `start_render_cb'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1931:in `direct_send'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1931:in `render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:1470:in `launch_vray_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:30:in `block in <module:VRayForSketchUp>'", "SketchUp:1:in `call'"]
Scene fully processed in 0.430 seconds
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby jiminy-billy-bob » Wed Dec 03, 2014 10:09 pm
When you open Sketchup with the ruby console opened*, do you see "Skatter overrode Vray's 'write_to_xml'" ?
*To have the console opened at startup, put the attached file in your plugins folder.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby andybot » Thu Dec 04, 2014 12:44 am
I should say, I keep vray unloaded at start and only load it with TT's vray tools. Does skatter integration depend on both extensions loading at startup? (i.e. does skatter load after vray in order to modify the xml write behavior?)
(I have no ruby or coding knowledge, so just guessing...)
andybot
Premium Member
Premium Member
Postby jiminy-billy-bob » Thu Dec 04, 2014 6:27 am
Ok yes, this is the reason.
I need to find a way to trigger my overwritting when Vray is loaded.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby valerostudio » Fri Dec 05, 2014 1:48 pm
Sorry for my delay in testing... I reinstalled and my previews are fixed, I get a random seed number now and V-Ray seems to be working. I will test some more today. So far, looking very good!
valerostudio
Postby valerostudio » Fri Dec 05, 2014 2:03 pm
We have something special here! This is by far the quickest and best looking grass I have rendering in VR4SU and I didn't even have to make a proxy! IT'S MAGIC!
valerostudio
Postby andybot » Fri Dec 05, 2014 3:21 pm
Well knock me over with a stuffed bear!! :ecstatic:
One minor thing I noticed is that it seems to be doing some negative scaling (you can see some of the bears are darker - usually a sign of flipped UV's from something being mirrored.) I had the default scaling and rotating turned on for this render.
andybot
Premium Member
Premium Member
Postby valerostudio » Fri Dec 05, 2014 10:22 pm
I always found that Compo Sprayer and Fur never really worked well for large populations, even in 2015 x64. This thing is a breeze. It doesn't seem to add any time to the parsing of the file, true?
valerostudio
Postby jiminy-billy-bob » Fri Dec 05, 2014 11:41 pm
andybot wrote:One minor thing I noticed is that it seems to be doing some negative scaling (you can see some of the bears are darker - usually a sign of flipped UV's from something being mirrored.) I had the default scaling and rotating turned on for this render.
This doesn't seem right. I'd be interested to test this model myself.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby jiminy-billy-bob » Fri Dec 05, 2014 11:47 pm
valerostudio wrote: It doesn't seem to add any time to the parsing of the file, true?
From what I tested, it does add parsing time. Quite a lot actually with big numbers of objects. But I am glad you don't see that. Good news :-)
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby andybot » Sat Dec 06, 2014 8:35 pm
yes, I've noticed some pretty long parsing time as well, definitely more than usual.
So here is the file I've been playing with. I got some darker bears even without the rotate or translate turned on. The object I'm using is a proxy component. It doesn't seem to be an issue with regular components.
http://www.mediafire.com/download/wo4oh ... roxy2b.zip
andybot
Premium Member
Premium Member
Postby jiminy-billy-bob » Mon Dec 08, 2014 1:25 pm
I'm not seeing darker bears when rendering the file you provided. But I'm wondering if it could be related to overlapping objects, since you have multiple similar Skatter objects in the render list.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby andybot » Mon Dec 08, 2014 2:14 pm
Ah, ok. It must have been related to multiple skatter setups. Starting with a clean file seems fine.
andybot
Premium Member
Premium Member
Return to Skatter
