[BUG] Nothing on surface
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby Rich O Brien » Tue Dec 02, 2014 10:00 pm
---- Skatter ----
Processing surface 1M_APt$Xz2hxUHZeMx4fxz
Points to lines : 0.0 s
View redraw : 0.034027 s
Total : 0.055042 s
------ End ------
I get nada ?
Rich O Brien
Administrator
Re: [RELEASE] Alpha 0.0.3
Postby Rich O Brien » Tue Dec 02, 2014 10:01 pm
Code: Select all
Error: #<NoMethodError: undefined method `[]' for -0.22452:Float>
C:/Users/Rich/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:215:in `block (2 levels) in find_faces'
C:/Users/Rich/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:215:in `map'
C:/Users/Rich/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:215:in `block in find_faces'
C:/Users/Rich/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/methods.rb:215:in `find_faces'
C:/Users/Rich/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jbb_skatter/rb/tools.rb:58:in `onMouseMove'
A bit more
Rich O Brien
Administrator
Postby jiminy-billy-bob » Tue Dec 02, 2014 10:03 pm
Could you share the model?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Dec 02, 2014 11:22 pm
marigold.skp
Rich O Brien
Administrator
Postby jiminy-billy-bob » Tue Dec 02, 2014 11:25 pm
Thank you.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Re: [BUG] Nothing on surface
Postby jiminy-billy-bob » Tue Dec 02, 2014 11:33 pm
Ok, I see the issue.
Your scale is wrong. The surface you are trying to scatter on is way too small compared to the default "spacing" value.
You can either scale up your objects, or decrease the the spacing (You'll get giant red spikes as preview)
As for the second error (not related to the first), it happens when you try to pick (as a surface or scattered object) the flowers. The issue is related to the hovering feedback, but you can still pick the object, it'll work.
I'll investigate and try to fix it.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Dec 02, 2014 11:38 pm
I thought I'd adjusted for that?
I'll experiment a bit more.
Rich O Brien
Administrator
Postby jiminy-billy-bob » Tue Dec 02, 2014 11:43 pm
Rich O Brien wrote:I thought I'd adjusted for that?
Well, it's really small :)
I had to put 1 inch by 1 inch to see only two projected points.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Rich O Brien » Wed Dec 03, 2014 10:49 am
Haha...i sent you the unscaled definition. at #1" tall. sorry.
Rich O Brien
Administrator
Return to Skatter
