Printing molds
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Printing molds
Postby ChemeJoo » Thu Feb 23, 2017 6:08 pm
Let's say I have a design for a chess piece, but I want to print out a mold using a 3d printer. I can't do this by simply 3d printing the chess piece. I have to 3d print a mold, which is an "inverse" of the chess piece because it would be a cube, with a hole in the shape of the chess piece. I would then pour the casting media into the mold.
Is there a way to delete an object from another object on sketchup?
ChemeJoo
Re: Printing molds
Postby Rich O Brien » Thu Feb 23, 2017 6:38 pm
Yes, it is called a Boolean operation.
If you have SU Pro it has these abilities
Rich O Brien
Administrator
Re: Printing molds
Postby Box » Thu Feb 23, 2017 11:36 pm
You can also just place the object inside a cube with its faces reversed and then split the whole thing in half, giving you two half molds.
Re: Printing molds
Postby gilles » Fri Feb 24, 2017 9:46 am
For SUMake with Outershell:
3
gilles
Top SketchUcator
Re: Printing molds
Postby Rich O Brien » Fri Feb 24, 2017 11:50 am
@gilles
8-)
That's super clever!
Rich O Brien
Administrator
Re: Printing molds
Postby d12dozr » Fri Feb 24, 2017 1:05 pm
Love your solution, Gilles! :fro:
For more complex models using Sketchup Make, you can also use the BoolTools plugin
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Re: Printing molds
Postby Box » Fri Feb 24, 2017 3:43 pm
Just to clarify my earlier comment.
There are many ways to modify geometry and it is important to learn the underlying structure.
First gif shows a manual split, second shows how an excellent plugin can automate it, once you understand how to do it.
Split by hand.
Split by Tig.
Re: Printing molds
Postby ChemeJoo » Sat Feb 25, 2017 5:12 am
So I've made the mold, but it doesn't export to Cura very well at all. I used a solid checker extension and all of the pieces are indeed solid.
I get a large yellow block in Cura. I used the "solid tools - subtract" on Sketchup to make the mold from the pieces.
ChemeJoo
Re: Printing molds
Postby d12dozr » Sat Feb 25, 2017 1:49 pm
Impossible to tell from your images, but if you upload the SKP model we can take a look!
d12dozr
Top SketchUcator
Re: Printing molds
Postby ChemeJoo » Mon Feb 27, 2017 3:40 am
It's fixed! I saved it as an STL file (with the STL extension) and it worked. I guess some file types simply aren't compatible.
ChemeJoo
Return to SketchUp for 3D Printing
