SketchUcation Premium Membership
Adding mist
Adding mist
Postby davidh » Thu Dec 15, 2011 12:49 pm
Attached is a step by step for creating mist:
1.create a new layer called mist and paint on with a white brush the extent of the mist
2.add a motion blur horizontally
3.add a motion blur vertically
4.duplicate the mist layer
5.use filter render/difference clouds
6.the second last image shows the difference clouds layer and the mist layer turned on
7.the last image shows only the difference layer turned on.
TIP:If you have added vegetation entourage by layers you can move the mist layer up or down to show the mist disappearing behind some elements and covering others.
davidh
Top SketchUcator
Re: Adding mist
Postby Rich O Brien » Thu Dec 15, 2011 12:52 pm
That's an excellent technique :thumb:
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Re: Adding mist
Postby dale » Thu Dec 15, 2011 3:05 pm
Just wanted to say how much I appreciate these tutorials. I use PS in post pro all the time, (usually due to time constraints) and your examples are really useful to me.
Thanks.
Just monkeying around....
dale
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Re: Adding mist
Postby boofredlay » Thu Dec 15, 2011 3:12 pm
Fantastic.
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Re: Adding mist
Postby Chris Fullmer » Fri Dec 16, 2011 6:05 am
I like that one a lot David. I'll see if I can use it somewhere in the future and post an example.
I don't live in a snowy area or do much in the snow, so many of the snow tutorials are lost on me :) BUT I do get some awesome fog here in my town. Thanks!,
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Re: Adding mist
Postby Bob James » Fri Dec 16, 2011 8:19 am
Much appreciated.
Indeed we do have fog on the California coast, but there are areas that are blessed with just mist :D
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: Adding mist
Postby pbacot » Sat Dec 24, 2011 7:18 pm
Thanks David, I will have to repeat the process to actually understand what you did here. Here's a thought when I saw your image. I see the sun peaking out in the picture...a challenge would be to hit part of the mist with some color?
Here is a picture I took on vacation. Your sun is not so bright, but it's the same idea.
I'm a little embarrassed to share here but to play along, here is an attempt with a picture of mine. Not a rendering but only one I have that has water. I found that I had to paint in the colored mist as a second process, similar to the first. I couldn't get a shaft of light affect. Probably wouldn't work at this scale FOV anyway. Then I had to add some flares and make a quick effect into a great bother :roll:
Top SketchUcator
SketchUp version: 8
License type: Pro
Re: Adding mist
Postby jsmith » Mon Jan 09, 2012 4:32 pm
WOWSER!
jsmith
Re: Adding mist
Postby zapwizard » Wed Jan 11, 2012 5:47 pm
So perfectly simple. Great tutorial.
zapwizard
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Return to Post Processing
